Quantized Dirac field calculations
The discussion revolves around the calculation of the fermionic propagator for the quantized Dirac field, specifically addressing steps in the derivation as presented in a referenced document. Participants explore the mathematical manipulations involved, including the treatment of integration variables and the implications of anticommutation relations in the context of causality.
  • One participant questions the validity of taking out the operator (iγ⋅∂+m) from a term that includes (iγ⋅∂-m) and seeks clarification on the difference between D(x-y) and D(y-x).
  • Another participant suggests that since p is an integration variable, it can be replaced with -p, proposing a method to resolve the first question raised.
  • A later reply expresses doubt about the implications of replacing p with -p, noting that the resulting expression does not yield -/not p without changing the sign of the energy component as well.
  • One participant reiterates the calculation of D(x-y) and D(y-x), providing detailed steps and emphasizing the role of the derivative operator acting on x rather than y.
  • Another participant acknowledges the explanation provided and expresses understanding of the sign changes involved in the calculations.
Participants express differing views on the manipulation of integration variables and the implications of anticommutation relations. The discussion remains unresolved regarding the specific mathematical steps and interpretations involved.
Participants highlight the importance of understanding the role of integration variables and the action of differential operators in the context of the calculations, indicating potential limitations in the assumptions made during the discussion.
Nod
Hi everyone!
I'm having a problem with calculating the fermionic propagator for the quantized Dirac field as in the attached pdf. The step that puzzles me is the one performed at 5.27 to get 5.28. Why can I take outside (iγ⋅∂+m) if the second term in 5.27 has (iγ⋅∂-m)? And why there's a difference of the D(x-y) and D(y-x)?
Since ##p## is an integration variable, in the second term in (5.27) you can replace ##p## with ##-p##. (More precisely, introduce a new variable ##p'=-p## and then remove the prime since it is a dummy variable.) With a little extra work, that should resolve your first question. The answer to the second question should be obvious from (5.29).
A more interesting comment on that page of Tong lectures is that the anticommutation relation does not violate causality because the fermion field is not an observable, while bilinear observables commute (not anticommute). That's an important lesson to those who like to interpret fields as "fundamental" objects.
I also thought like this, but still I have doubts:
If I replace ##p## with ##-p##, then instead of
##\displaystyle{\not} p = γ_μ p^μ = γ_0 p^0 +γ_i p^i##
I'll have
##\displaystyle{\not}p = γ_μ p^μ = γ_0 p^0 -γ_i p^i##.
But the last equation is not equal to ##-\displaystyle{\not}p## , because for that also the energy part ##γ_0 p^0## must change the sign!
Nod said:
Hi everyone!
I think it's pretty straightforward:
[itex]D(x-y) = \int \frac{d^3 p}{(2\pi)^3} \frac{1}{2E_p} e^{-i p \cdot(x-y)}[/itex]
So: [itex](i \displaystyle{\not} \partial + m) D(x-y) = \int \frac{d^3 p}{(2\pi)^3} \frac{1}{2E_p} (+\displaystyle{\not} p + m) e^{-i p \cdot(x-y)}[/itex]
[itex]D(y-x) = \int \frac{d^3 p}{(2\pi)^3} \frac{1}{2E_p} e^{-i p \cdot(y-x)} = \int \frac{d^3 p}{(2\pi)^3} \frac{1}{2E_p} e^{+i p \cdot(x-y)}[/itex]
So: [itex](i \displaystyle{\not} \partial + m) D(y-x) = \int \frac{d^3 p}{(2\pi)^3} \frac{1}{2E_p} (- \displaystyle{\not} p + m) e^{-i p \cdot(x-y)}[/itex]
Subtract the two and you get:
[itex](i \displaystyle{\not} \partial + m) D(x-y) - (i \displaystyle{\not} \partial + m) D(y-x)[/itex]
[itex]= \int \frac{d^3 p}{(2\pi)^3} \frac{1}{2E_p} ((+ \displaystyle{\not} p + m) e^{-i p \cdot(x-y)} - (- \displaystyle{\not} p + m) e^{-i p \cdot(x-y)})[/itex]
You have to remember that [itex]\partial[/itex] acts on [itex]x[/itex], not [itex]y[/itex], and that [itex]i \displaystyle{\not}\partial e^{\mp i p \cdot (x-y)} = \pm \displaystyle{\not}p e^{-i p \cdot (x-y)}[/itex]
Thank you for explanation! Now I get where the signs come from :)
  • · Replies 24 ·
