Understanding Quantum Gravitation: Planck's Radius, String Theory, and More
In summary: Planck length and the string coupling constant.In summary, Quantum Gravitation String Theory is a theory that involves the relationship between distance and momentum, as well as the Planck's Radius and the minimum observable length for a quantum string. Alpha Prime is a constant for a Planck Scale Bosonic String, and String Tension and Quantum Gravitation String Tension are also important factors in this theory. Additionally, the concept of Bosonic and fermionic hadronic Regge trajectory resonance is relevant in this theory, and Alpha prime is also known as Regge slope. However, there are some discrepancies in the given formulas, as alpha prime is actually a variable rather than a constant. This theory
Orion1
973
Quantum Gravitation String Theory:
Planck's Radius:
[tex]r_p = \sqrt{ \frac{ \hbar G}{ c^3}}[/tex]
Minimum observable length for a quantum string:
[tex]r_m = 2 \sqrt{ \alpha '}[/tex]
Planck's Radius is minimum observable length for a quantum string:
[tex]r_p = r_m[/tex]
Planck area of the hyperspace amplified Salam G* strong short range low energy gravity.
[tex]\sqrt{ \frac{ \hbar G}{ c^3}} = 2 \sqrt{ \alpha ^'}[/tex]
Alpha Prime:
[tex]\alpha ' = \frac{ \hbar G}{ 4 c^3}[/tex]
Alpha Prime is constant for a Planck Scale Bosonic String.
String Tension:
[tex]T_s = \frac{ 1}{2 \pi \alpha '}[/tex]
Quantum Gravitation String Tension:
[tex]T_g = \frac{ 2 c^3}{ \pi \hbar G}[/tex]
Relationship between distance and momentum:
[tex]\Delta L = \frac{ \hbar}{ p} + \alpha ' \frac{ p}{ \hbar}[/tex]
Quantum Gravitation distance and momentum:
[tex]\Delta L = \frac{ \hbar}{ p} + \frac{ G p}{4 c^3}[/tex]
Bosonic and fermionic hadronic Regge trajectory resonance:
[tex]J = \alpha ' E^2[/tex]
[tex]J = \frac{ \hbar G}{ 4 c^3} E^2[/tex]
[tex]E = \sqrt{ \frac{ 4 J c^3}{ \hbar G}}[/tex]
Reference:
http://superstringtheory.com/basics/basic3a.html
http://www.lepp.cornell.edu/spr/2001-05/msg0032717.html
Nice summary of formulas. Your second formula is problematic because it means that in superstring theory there's a minimum distance that you can measure, the distance given by the formula. Alpha prime is also called Regge slope
Your fifth formula, the formula that you give for alpha prime is incorrect. Alpha prime is not a constant
Quantum gravitation is a branch of theoretical physics that aims to unify the theories of gravity and quantum mechanics. It is still a subject of ongoing research, and there are various theories and equations that attempt to explain this phenomenon. One of the key concepts in quantum gravitation is Planck's Radius, which is the minimum observable length for a quantum string. This radius is given by a formula that involves fundamental constants such as Planck's constant, the gravitational constant, and the speed of light.
Another important concept is string theory, which proposes that all particles in the universe are made up of tiny vibrating strings. The minimum observable length for a quantum string is also related to the string tension, which is the energy required to create a string. This tension is given by a formula that involves the constant alpha prime, which is a fundamental constant for a Planck scale bosonic string.
One interesting relationship in quantum gravitation is between distance and momentum. In classical mechanics, the uncertainty principle states that there is a limit to how precisely we can know the position and momentum of a particle. In quantum gravitation, this relationship is given by a formula that involves the Planck constant and the string tension.
Finally, the bosonic and fermionic hadronic Regge trajectory resonance is a concept that describes the energy levels of particles in quantum gravitation. This trajectory is given by a formula that involves the Planck constant, the gravitational constant, and the energy of the particle. Overall, understanding quantum gravitation involves understanding these fundamental concepts and their relationships, and ongoing research in this field continues to deepen our understanding of the fundamental forces of the universe.
1. What is quantum gravitation?
Quantum gravitation is the theoretical framework that attempts to reconcile the principles of quantum mechanics (which describes the behavior of particles on a very small scale) with the principles of general relativity (which describes the behavior of large-scale objects and the force of gravity).
2. What is Planck's radius?
Planck's radius is the theoretical minimum distance at which the laws of quantum mechanics and general relativity break down. It is approximately 1.6 x 10^-35 meters, which is about 10^-20 times smaller than the size of a proton.
3. How does string theory relate to quantum gravitation?
String theory is a theoretical framework that attempts to unify all of the fundamental forces of nature, including gravity. It proposes that particles are not point-like objects, but rather tiny, vibrating strings. This theory is still a work in progress and has not yet been proven, but many physicists believe it has the potential to explain quantum gravitation.
4. What is the difference between quantum gravitation and classical gravitation?
Classical gravitation, described by Isaac Newton's laws of motion, explains the force of gravity as a result of the mass and distance between two objects. Quantum gravitation, on the other hand, attempts to explain gravity on a much smaller scale, where the principles of quantum mechanics come into play.
5. How does understanding quantum gravitation impact our understanding of the universe?
Understanding quantum gravitation is crucial for fully understanding the fundamental laws and forces that govern our universe. It could potentially lead to a unified theory of physics, and help us better understand the behavior of matter and energy on a microscopic level. It may also have implications for our understanding of the origins and evolution of the universe.
  • Beyond the Standard Models
