Quantum Mechanics: Expected momentum of a real wavefunction
galaxyrocker
Given the wavefunction, \psi(x) = Cx for 0 < x < 10 and \psi(x) = 0 for all other values.
What is the normalization constant of C? I got \sqrt{3/1000}.
What is <x>? I got 30/4.
What is <p>? Here is where I'm confused.
\langle p \rangle = C^2 \frac{\hbar}{i} \int_0^{10} \psi^* \frac{d}{dx} \psi \, dx
I worked out the integral, and got (3/20)(\hbar/i).
It's here that I can't figure out whether to leave it as that, or say it's 0, since the momentum is an observable, and must be real. I realize that the function is odd, but I'm not integrating it from -a to a, which means I can't just say it's 0 for that reason.
[strike]PS: Sorry for my horrible usage of LaTeX.[/strike]
Mod note: Fixed your LaTeX for you.[/color]
Try integrating by parts. Also, your notation is not good. You already pulled the C's out of the integral so it should be \langle p \rangle = C^2 \frac{\hbar}{i} \int_0^{10} x \frac{d}{dx} x \, dxNVM the above ;(. Think about it. You know that <p> is real and you get a purely imaginary result. What can you conclude? ;)
I conclude that I am either wrong, or that <p> = 0. I'm inclined to the former, but the latter makes sense, because if I was integrating around the origin (say, from -5 to 5 instead), it would cancel.
But your integral goes from 0 to 10, so <p> = 0.
Yes.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
