Can Quantum Tunneling Explain the Energy Released by the Sun?
In summary: There is a physical limit to how much you can observe, but it's not the uncertainty principle.Quantum mechanics does not predict that all the particles in the sun will collapse into a single point when observed. The Heisenberg uncertainty principle places limits on how much we can measure, but it is not a limit on the uncertainty principle.
Jimmy87
686
Hi pf,
I'm fairly new to QM so this may seem like a trivial question. As I understand it, an electron (or any small particle) does not have a definitive position in space until it is observed which causes the quantum wave like nature of the particle to disappear (collapse of the wave function). For example, in the electron double slit experiment, the electron behaves like a wave showing an interference pattern until you try to measure which slit it goes through which causes the wave function to collapse and the pattern resembles two peaks rather than an interference pattern.
From what I have read, the energy released by the Sun cannot be fully explained without taking into account quantum tunneling. This seems to be explained by the quantum wave like nature of particles which means since two protons can be in many places at once (due to their wave like nature) some of these places result in these particles tunneling through the electrical repulsion barrier and fusing together. This sounds silly but if you use the same logic for the effects of observation on quantum objects for the double slit experiment then what would happen if you were to simultaneously try to observe all the protons in the Sun (obviously this is impossible). If you could observe all the protons in the Sun then effectively wouldn't all their wave functions collapse and you would have no quantum tunneling and the Sun would produce less energy?
You misunderstand. Quantum objects are not in two places at once, they are not in ANY place until observed. It actually makes no sense to talk about the "position" of a quantum object until it is observed and then it is in one place.
Thanks. This video () from 40 seconds - 1min 30secs seems to say that particles have a wave like behaviour so there is a probability that such particles in the Sun can be found close enough together to fuse. But if you observe the position of all the particles in the Sun then surely they will exhibit no wave like behaviour so the quantum tunneling effects will go away?
Quantum object do exhibit wave-like characteristics if that's what you measure for (and particle-like behavior if that's what you measure for), but I don't know enough to comment on whether your thesis about tunneling is sound. In practical terms, of course, it doesn't matter since it is impossible to do what you require experimentally (as you already realize).
In quantum mechanics, observe means to interact with a detector. Observation only collapses a wavefunction for the parameter which is observed, and only to the extent that it is observed. Mathematically, it is a projection operator. Heisenberg uncertainty principle puts some limits on what you can observe. In order to measure the protons of the Sun in a way you envision, you would have to capture the protons into a larger device. While they are captured by the device, the protons might have trouble fusing. But when you release the protons, their wavefunctions will spread out again and they'll start fusing again.
1. What is quantum tunneling in the sun?
Quantum tunneling in the sun is a phenomenon in which subatomic particles, such as protons, are able to pass through the potential barrier of the sun's core, despite not having enough energy to do so according to classical physics. This allows for nuclear fusion to occur, creating the energy that sustains the sun's heat and light.
2. How does quantum tunneling contribute to the sun's energy production?
Quantum tunneling is a crucial process in the sun's energy production. Without it, the subatomic particles would not be able to overcome the potential barrier and fuse together, creating the immense energy that powers the sun.
3. Can we observe quantum tunneling in the sun?
While we cannot directly observe quantum tunneling in the sun, we can detect its effects through measurements of the sun's energy output and the byproducts of nuclear fusion, such as neutrinos.
4. Is quantum tunneling unique to the sun?
No, quantum tunneling is a phenomenon that occurs in many other systems, including atoms, molecules, and even in our own bodies at the cellular level. However, in the sun, quantum tunneling plays a crucial role in sustaining its energy production.
5. How does quantum tunneling relate to the sun's lifespan?
The rate of nuclear fusion in the sun, which is dependent on quantum tunneling, determines the amount of energy it produces and ultimately affects its lifespan. As the sun uses up its hydrogen fuel, the rate of quantum tunneling will decrease, leading to a decrease in energy production and the eventual end of the sun's lifespan.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
