Assessing Modulation Index in AM Demodulation: Techniques and Limitations
  • Thread starter Thread starter watertreader
The discussion focuses on techniques for assessing the modulation index in AM demodulation. Two primary demodulation methods are identified: synchronous detection and envelope detection. The proposed techniques for measuring the modulation index include using FFT to analyze the spectrum height at the modulation frequency or calculating the difference between the maximum and minimum signal values over time. Concerns are raised about the limitations of these methods, particularly their effectiveness in low-frequency and low-distortion scenarios. The discussion concludes with a consideration of the ideal conditions necessary for these techniques to yield accurate results.
watertreader
hi,
Just want to have some comments on the AM Demodulation steps that I have taken.
A AM modulated signal is given by AM(t) = DC + m cos(wt)
For the general demodulation technique, I understand there is two general form - (i) Synchronous Detection whereby you mix the input wave with an local oscillator signal or in more advance form by using a 90 degree phase delay signal to get the quadrature as well (ii) Envelope detector - wherby we will just detect the envelope of the input with an diode and cap.
Now if we would just want to have the knowledge of the modulation index instead of recovering the whole wave. I am thinking of the following method
1) compute the FFT of the signal and measure the spectrum height at the modulation frequency (as a representative value of modulation)
Or
2) Compute the difference between the maximum and minimum signal off the signal at time axis
Would this be appropriate? I can only think of the problems would be that both techniques usage would be restricted to low frequency and low distortion cases.
Like to have your comments
Thanks
Technically, I am trying to find M only. I am just wondering if my technique has any other drawbacks or whether would it be sufficient
1) Using FFT method essentially separate the A and M. A is in the DC while M or rather M/2 is sited with the modulated signal frequency
2) Using the subtraction method, effectively I cancel out A... What is left is the M index...
That is assuming the condition are pretty ideal.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
