Question about a derivation of jackson
ptabor
in the introduction to jackson's classical electrodynamics, he states that the number of photons incident to a 1 square centimeter area in 1 s for a 100W bulb (1 m away) is on the order of 10^15.
also he gives a similar quantity for an FM antenna operating at 100W at a frequency of 10^8 Hz.
what's the derivation for these numbers?
I suspect that you need to find the intensity of the beams, then multiply by the 1 cm square to get the total energy - and then divide by the energy of 1 photon ( given by E = hf ).
what I don't know is how to get the intensity.
The intensity is the power (given) divided by the surface area of a sphere 1 m in radius.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
