How to Calculate the Index of Refraction of Acetone?
  • Thread starter Thread starter kevinf
    Light Refraction
To calculate the index of refraction of acetone, students can use Snell's Law, which states that sin(theta1)/sin(theta2) = n2/n1. In this case, theta1 is the angle of incidence (30 degrees) and theta2 is the angle of refraction (42 degrees). The refractive index of air is considered to be 1, allowing the equation to simplify to sin(42)/sin(30) = n2/1. This calculation yields an index of refraction for acetone of approximately 1.34. The discussion confirms that using Snell's Law is the correct approach for this calculation.
kevinf
A pair of students measure the refraction of light in passing from acetone into air for several angles. When the angle of incidence is 30, the angle of refraction is 42.
(a) What is the index of refraction n of the acetone?
n=c/v
i am not sure if there is another way to calculate the index of refraction. i can't find v (speed of light in acetone) so i don't think the provided equation will work. is there another way to calculate it? i also searched up google for index of refraction for acetone and it gave me 1.36 but even that's not correct. any ideas?
You will find your answer by googling Snells law
ok so snelll's law says sim(theta1) /sin(theta2) = n2/n1. wouldn't i still need to know the index of refraction for air? or is that a constant that is usually given?
You will find your answer by googling index of refraction for air.
The refractive index of vacuum is 1 and the refractive index of air is slightly higher,the difference,however, is so very small that we take the refractive index of air as being 1.
so just to make sure it would be sin(30)/sin(42) = n2/1? i just want to make sure since this is my last try
sin42/sin30.This gives the refractive index of acetone from air.
so sin(42)/sin(30) = n2/1? so it should be about 1.34 right?
Yes.:biggrin:
