sophiecentaur
- 30,096
- 7,381
To maximise the power delivered from the feeder into the antenna you need to match at the drive point - that's straightforward enough and you try to minimise your VSWR / reflection coefficient at the join.
To get power actually into the feeder from the transmitter there has to be some degree of matching. A low impedance output stage will not drive much power into a high impedance load without using massive voltages - and vice versa. But, as you imply, conway, there are practical limits to how well you can match a (probably non-linear) amplifier stage and there will be inherent losses in the device in any case. I don't think that there are any particular design problems for 'bog standard' frequency operation, these days. They seem to build big HF transmitters a bit like audio amps these days - class B push pull blah blah.
To avoid echoes, over voltage and or odd frequency response, it is necessary to match at least one end of a feeder.
