Can a Sequence with a Limit of p be Called Infinite?
  • Thread starter Thread starter amanda_ou812
    Sequences
amanda_ou812
If I have a sequence {Pn} and I know that lim Pn = p, can I call {Pn} infinite? I am trying to use this result in a real analysis proof. I know B(p; r) intersection S is non-empty and I need to show that it has indefinitely many points. I can show that {Pn} is a subset of S and is also a subset of B(p;r). So, if {Pn} is infinite, then B(p;r) intersection S would have indefinitely many points. Our definition of {Pn} is not strictly defined. Just that n is a natural number. I know that sequences can be finite or infinite but I am not sure of the definitions. Thanks!
Do you have a definition for the limit of a sequence?
We are using the definition: Let (X, d) be a metric space, {pn} is a subset of C and is a sequence in X and p is an element in X. We say that the sequence converges to p and write lim (as n-> infinity) pn = p provided that for every e>0, there is a real number N so that when n>N the d(p, pn)<e
Sorry, {pn} is a subset of X
You wrote, "lim (as n-> infinity) pn = p". Doesn't that imply that if a sequence does converge to a limit, then it must be an infinite sequence ?
Added in Edit:
Of course, just because a sequence is infinite, it doesn't follow that all of its terms are distinct.
hm...I see your point. So, {pn} infinite and {pn} as a subset of B(p; r) intersection S does not imply that B(p;r) intersection S has indefinitly many points. Is there another way I can get to that conclusion?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
