Question about static equilibrium
The discussion revolves around calculating the force needed to make a 15-foot ladder slide against a smooth wall while maintaining static equilibrium. The ladder weighs 20 lbs and is positioned at a 45-degree angle, with the user attempting to determine the force of pull required at the midpoint. Key equations for force and torque balance are established, but confusion arises regarding the correct application of these equations and the number of unknowns involved. Participants emphasize the importance of drawing a free body diagram and working symbolically to avoid errors in calculations. The conversation highlights the need for clarity in the signs of forces and the relationship between normal force and static friction to solve the problem accurately.
bioengi12345
A Ladder weighs 20 Lbs. IT rests against a smooth wall at point B. Theta=45. If you pull the ladder at its midpoint, how much force is needed to make it slide at point A? u=.6.
The ladder is 15 ft long, Point b is the top and point A is the bottom. 45 Deg is the bottom angle.
Force of pull= 20lb. Now i think the number worked out this was just cause the angle is 45 degrees and gravity as well as the force of the pull act about the same point, however, this just seems like that it would take to tip the ladder backwards, not make it slide. I am not really sure where to go from here.
(sum of forces in x dir) : Force of pull - force of static friction = 0
(sum of forces in y dir) : -20 + normal force at A = 0
(sum of moments about A) : -20lb(5.3m)-force of pull(5.3m) = 0
Anyone have any ideas?
You forgot the normal force from the wall.
To make the ladder just slide, but not tip over, both the resultant force components and the torque have to be zero.
So it would be: Force of pull - Force of static friction - normal force of the wall=0? Then i have 3 unknowns. Sorry I am normally really good at this stuff, the whole idea of equilibrium gets me sometimes.
Three unknowns is fine since in 2D statics problems you have three equations.
Is the direction of pull given?
pulling horizontally away from the wall at the midpoint.
This problem actually has four unknowns, but also four equations. (although only three are needed to solve it)
Ok, so have you drawn a free body diagram? Why do you write "force of pull = 20 lbs"? Isn't that what we're to find?
Create symbols for the known and unknown forces and lengths. Work symbolically until the final step. Write three equations: one for horizontal force balance, one for vertical force balance, and one for torque balance. (Choose a reference axis for the torque.)
Im trying to say that is what i got as the answer but i don't think its right. I haven't made a whole lot of progress here some direction would be very helpful. i have set up 3 equations. sum of f in x ( fp-fs-nB=0, -20+nA=0, -20(5.3m)+fP(5.3)+nB(10.6)=0 ... is any of this looking right? i need to get this turned in so some solid hint would be very nice.
When you put all of that together, what do you get for fP ?
First, you had not previously posted that version of your equations; second, you have a sign wrong in the x direction balance; third, you would do well to work entirely symbolically as I suggested (it avoids the units conversion); fourth, you have not used the fact that you are interested in the case where the friction is only just enough to balance the forces.
I presume you no long claim 20lbs as an answer.
Check the sign in front of nB.
Use the relation between NA and fs.
