I Question about time-variant Schrodinger's eq'n
  • I
  • Thread starter Thread starter woody stanford
    Schrodinger equation
woody stanford
The question I have is regarding the time-variant form of schrodinger's equation. Can I just put a complex number of form c=a+bi where the i is in it or can I just literally put sqrt(-1) where the i is:
addendum: sorry forgot the t in the right-hand term, it should read (r,t) instead of (r)
Also any comments/insights on some of the other terms in it would be welcomed (as I'm writting a c program to inject various values into it) and would appreciate the help.
Was thinking if I could just put a+bi in there that to put it back to i all I would have to do is set (real)a=0 and (imaginary)b=1
I think you are going to have to treat it as a complex number and make sure you use complex arithmetic throughout.
See that's why I come here...get a few opinions...a few facts...a few points of view. Thank you sir. Basically what I was thinking but wanted to bounce it off the ole colleagues. Means I'm not nuts (comforting to know). lol
OK, got some more question.
Still working on my program to compute the time invariant version of SE. Here is that equation:
Ok, here is my question. The E here I believe can have a Hameltonian substituted in BUT I'm interested in the classic interpretation of the E term here. Is it system total energy? I assume it has a local associated with it, but what "energy" does it represent?
Is it the mass terms converted to energy via the equation e=mc^2? Is it the total kinetic energy of all particles within the local system being described? What exactly does that E term mean?
...(and don't reference a Hameltonian unless it gets me closer to what I'm looking for...in other words if you invoke the Hameltonian option you will be required lol to explain it from there, not from the easier to explain E at that point)?
Addendum: ok, came up with a hypothetical E value based on the relation E=h/wavelength since I'm using a psi(x)=A*sin(kx+d) wave function that I believe is for [the electrical component for] a beam of light (ie. photon). I'm using a 500 nm (visible red) beam of light in the simulation btw (if it helps).
E=h/wavelength
Always good to learn the language: they are called the time-dependent and time-independent Schrödinger equation.
There is a lot of confusion here. You can't "substitute" E for a Hamiltonian, since you have the Hamiltonian on the left-hand side. E is a scalar, and it is indeed the energy of the system. To be more precise, it is one of the eigenenergies. (You do know what an eigenvalue problem is?) Also, you don't need to invoke a "classical interpretation" for E.
This is purely non-relativistic, so there is no ##mc^2## term. To know what the energy corresponds to, you have to look at the Hamiltonian. In your case, the first term is the kinetic energy, while the second is an unspecified potential ##V(x)##. So the total energy is kinetic + potential energy, with the potential energy correspond to whatever lead to the presence of a position dependent potential ##V(x)## is the first place.
E=h/wavelength
You can't use that Hamiltonian to describe a beam of light. This is only for a massive particle. And if you want to talk about photons, you'll have to upgrade to quantum electrodynamics, which I guess is not what you want to do here.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
