Question About Torque and Stepping Motors
  • Thread starter Thread starter julianwitkowski
    Motors Torque
High torque stepping motors can provide acceleration torques ranging from 3.6 N-m to 360 N-m, with continuous output torque varying from 1.2 N-m to 120 N-m. To calculate the mass a motor can move, the relationship between torque, radius, and gravitational force must be considered, specifically using the formula M_max = τ/(gR). When lifting vertically, the maximum mass is determined by the torque divided by the product of gravity and the wheel radius. For horizontal movement, friction must also be accounted for, complicating the calculations. Understanding these dynamics is crucial for accurately assessing the motor's capabilities in practical applications.
julianwitkowski
I'm looking for a high torque stepping motor for a project.
How do I calculate much mass this can move ?
1.2 N-m = 1.2 J = Force ⋅ Distance = 1.2 kg⋅m2/s2
Does this mean it has the energy to move 1.2 kg, 1m, in 1 second?
I'd believe that, but 120 kg, 1m, in 1 second seems way too good so I'm wondering what I'm not thinking about here...
For example, let's say that you connect to the motor axis a wheel of radius ##R##. This wheel pulls a rope at which is commented your mass ##M##, which you have to lift vertically by going against gravity ##g##. Then ##M_{\text{max}} = \dfrac{\tau}{g R}##, where ##\tau## is the output torque of the motor.
If you just have to move the mass horizontally you have to take into account the friction force of the plane, and solve ##\mu M_{\text{max}} R = \tau##, where ##\mu## is for example the kinetic friction coefficient of your surface, which usually you do not know.
Likes julianwitkowski
Thank you very much.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
