Question: Capacitors, Time Constant and p.d.
A capacitor charged to 1V was measured over time, showing an exponential decay in voltage after a resistor was connected at 30 seconds. The current in the resistor at that moment was calculated using Ohm's law, yielding approximately 6.67 x 10^-7 Amps. To determine capacitance, the relationship C = IT/V was discussed, with emphasis on using appropriate values for current and voltage. The voltage decay follows the equation V_C = V_o e^{-t/τ}, where the time constant τ can be derived from the gradient of the ln(p.d.) graph. The discussion highlights the importance of accurately measuring the time constant for reliable capacitance calculations.
ProD
if anyone could help me on this it would be much apreciated, thanks :smile: .
Question:
A capacitor was joined across a digital voltmeter and charged to a p.d. of 1V. the p.d. was then measured at 20s intervals and at t=30s a resistor (R=1.5 mega ohms (1500000ohms)) was connected across the capacitor.
The following results were obtained:
time (s) 0.00 * 20.0 * 40.0 * 60.0 * 80.0 * 100.0 * 120.0
p.d. (V) 1.00 * 1.00 * 0.81 * 0.54 * 0.35 * 0.23 * 0.15
a) what is the current in the resistor at t=30s?
b) plot a graph of p.d. against time and measure the rate of decrease of p.d immediately after t=30s
c) hence calculate the capacitance of the capacitor
d) i) plot a graph of ln(p.d.) against timine (t) to demonstrate the ecponential fall of p.d.
ii) deduce the time constant of the decay process.
e) use your value of the time constant to calculate a second value for the capacitance of the capacitor.
f) explain which method of finding C gives the more reliable value.
My thought:
a) V=IR
I=V/R
I=1/1500000
I=0.000000667 Amps or (6.67Exp-7)
b) *drawn graph on paper* for the rate of decreasing p.d. do i take the gradient of the graph after 30s?
dy/dx... in this case...dV/dt
c) C=Q/V
Charge (Q) is not know so substitute Q=IT
therefore: C=IT/V
what values do i take for the time and voltage, do i use the ones i used to find the current in part (a)..?
d)
i) *done on paper*
ii) time constant = RC
R=1.5Exp6 ohms
C= value found in part (c)??
e) ?
f) ?
Thanks in anticipation
Welcome to PF ProD.
a) is OK.
For c):
According to the theory the discharge voltage decays exponentially
V_C = V_o e^{-\frac{t}{\tau}}
which means that the gradient of the graph will be
grad \ =-\frac{1}{\tau} V_C
so the positive inverse of the gradient gives the capacitive time constant, \tau = RC, of the circuit - we assume that V_C = 1.0\ V at 30 seconds.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
