Question concerning solubility equilibriums for salts
  • Thread starter Thread starter Nikitin
    Solubility
In this discussion, the focus is on the solubility product constant (Ksp) of a salt with low solubility and the implications of its concentration in solution. The key point is that in the expression for Ksp, the concentration of the undissolved salt ([AB]) is often treated as constant and can be considered equal to 1 because it represents the activity of the solid phase rather than its concentration in solution. This means that when a weakly soluble salt is added to water, the concentration of the dissolved ions ([A+] and [B-]) is what matters for calculating Ksp, while the undissolved salt remains in a separate phase and does not contribute to the concentration in the solution. This concept is illustrated through the analogy of a large crystal of salt acting as a wall, where the concentration of the undissolved substance in the solution is effectively zero, but the ions can still enter the solution from the solid phase.
Nikitin
Hi. Let's say we have a salt AB with a very low Ksp. A bunch of it gets thrown into the water and mixed.
So:
K=[A+][B-]/[AB].
Ksp=[A+][B-]
Why is it OK to remove [AB], then? ie why does [AB] equal 1? I thought [AB] was concentration of the substance in the water, but it is the substance's activity in the water, according to wikipedia?
Please explain this so a high-schooler can understand.
Chemistry news on Phys.org
[AB] would be concentration of the substance, but the substance is not dissolved.
Imagine you have a single large crystal of a weakly soluble salt, that is a wall of the vessel in which you are dissolving the substance. Concentration of the undissociated substance in the solution is zero, however, it is in the contact with water, so the ions can can be leached into the solution. When you have smaller crystals situation is identical, they form a separate phase.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
