Question from Dirac's Principles of QM
  • Thread starter Thread starter Jimmy Snyder
    Qm
Jimmy Snyder
I have the fourth edition of Dirac's Principles of QM. I have a question concerning the equation in the middle of page 102 (between eqns 64 and 65 in section 25.)
\lim_{\delta x \rightarrow 0}(De^{i\gamma} - 1)/\delta x = \lim_{\delta x \rightarrow 0}(D - 1 + i \gamma)/\delta x
If you make the substitution e^{i\gamma} \simeq 1 + i \gamma then it seems to me you should get
\lim_{\delta x \rightarrow 0}(De^{i\gamma} - 1)/\delta x = \lim_{\delta x \rightarrow 0}(D - 1 + i \gamma D)/\delta x
What am I missing?
You aren't missing anything. Is it a typo?
Dick said:
Is it a typo?
I doubt it. The conclusion he correctly draws from this equation is that the displacement operator is indeterminate by an arbitrary additive pure imaginary number:
ia_x = \lim_{\delta x \rightarrow 0}i \gamma/\delta x
If it were a typo, then the the right hand side would also need to be operated on by D and then would not be a number. Is there some reason that D(i\gamma) = i \gamma?
Never mind, I finally figured it out. Thanks for your help. The solution is that
\lim_{\delta x \rightarrow 0}D = 1
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
