Question on an example in Griffiths' book, Not a homework
The discussion centers on an example from Griffiths' book regarding the calculation of current density from a given vector potential. The user expresses confusion over the book's assertion that the current density, J, equals zero, despite their calculations suggesting otherwise. Several participants point out potential errors in differentiation and the application of Maxwell's equations. Ultimately, the user realizes that their previous calculations were incorrect, leading to the conclusion that the current density indeed equals zero. The conversation highlights the importance of careful differentiation and understanding of electromagnetic theory in solving such problems.
yungman
The is example 10.1 in page 417. The example is the find the current density from given condition:
V=0,\;\;\hbox{ and } \;\;\vec A=\frac{\mu_0 k}{4c}(ct-|x|)^2 \hat z \;\hbox { for x = +ve and }\;\; \vec A=0 \;\;\hbox { for x = -ve.}
c=\frac 1 {\sqrt{\mu_0 \epsilon_0}}
From this, you get:
\vec E= -\frac {\partial \vec A}{\partial t} \;=\; -\frac {\mu_0 k}{2} (ct-|x|)\hat z \;\;\;\hbox { and }\;\;\; \vec B = \nabla X \vec A = ^+_- \hat y \frac{\mu_0 k}{2c}(ct-|x|)
\nabla X \vec B = -\hat z \frac {\mu_0 k}{2c} = \mu_0 \vec J + \mu_0 \epsilon_0 \frac{\partial \vec E}{\partial t} = \mu_0 \vec J -\hat z \mu \epsilon_0 \frac{\partial^2 \vec A}{\partial t^2} = \mu_0 \vec J - \hat z \frac{\mu_0 k c}{2}
\Rightarrow \vec J = -\hat z \frac {\mu_0 k}{2c} + \hat z \frac{\mu_0 k c}{2}
The book claimed \vec J = 0 without going through the steps.
I cannot get that, please help.
Thanks
Alan
The \vec{B} doesn't look correct. Can you check your differentiations ?
Thanks for the reply.
\hbox{ If x = +ve }\; |x|=x \;\Rightarrow \;\frac { d |x|}{dx}=1.\;\;\;\hbox { If x = -ve }\; |x|=-x \;\Rightarrow \; \frac { d |x|}{dx}=-1
I don't know how to put it in determinant form use Latex so I just give the result:
\vec B = \nabla X \vec A = -\hat y \frac {\mu_0 k}{4c} [2(ct-|x|)] [-(^+_-1)]
\hbox { Where }\;[-(^+_-1)]\; \hbox{ stand for -1 if x is possitive and +1 for x is negative. }
Where +ve where x is possitive and -ve when x is negative.
The book gave this for B also. I think this is correct. I skip typing in a lot of step to avoid boring people with the detail.
I just change the \;c = \frac {1}{\sqrt { \mu \epsilon }} \; \hbox { to }\;\frac {1}{\sqrt { \mu_0 \epsilon_0 }}. This tell you that the dielectric is vacuum or air and is lossless. \vec J \;\hbox { is free current density }\;\Rightarrow\; \vec J = \sigma \vec E =0 when \sigma = 0. Maxwell's equation cannot verify that!
Can anyone help, it really don't make sense!?
looks to me like you forgot the 1/c2 factor of the dE/dt term
in the curl(B) equation.
I cannot see anything wrong, here is a more detail derivation:
\frac{\partial \vec E}{\partial t} = -\hat z \frac{\partial^2 \vec A}{\partial t^2}= -\hat z \frac {\mu_0 k}{2} \frac{\partial (ct-|x|)}{\partial t} = -\hat z \frac{\mu_0 k c}{2}
\nabla X \vec B = -\hat z \frac {\mu_0 k}{2c} = \mu_0 \vec J + \mu_0 \epsilon_0 \frac{\partial \vec E}{\partial t} = \mu_0 \vec J -\hat z \mu_0 \epsilon_0 \frac{\partial^2 \vec A}{\partial t^2} = \mu_0 \vec J - \hat z \frac{\mu_0^2 \epsilon_0 k c}{2}
I did forget to put back \mu_0 \epsilon_0 in the original post but that still will not make \mu_0 \vec J equal zero. Most of the equations are in the book also. My confident with these equation is very high. It is more about something I totally miss and is not here.
Given the medium is characterized by \mu_0 \epsilon_0, you cannot have current density anywhere except at the discontinue at x=0 where there is surface current density. The problem is Putting the equations into the Maxwell's equation does not yield J=0 in the Maxwell's curl equation as shown. The only thing that can be wrong is that I should not try to put this into the Maxwell's curl equation like this. And if so, I really want to hear the reason why.
Thanks
Alan
Come on, Alan. This is an extract of what you wrote:
-\hat z \frac {\mu_0 k}{2c} = [...] = \mu_0 \vec J - \hat z \frac{\mu_0^2 \epsilon_0 k c}{2}
So
\mu_0 \vec{J} = -\hat z \left(\frac{\mu_0 k}{2c} - \frac{\mu_0 \mu_0 \epsilon_0 k c}{2}\right)
But \mu_0 \epsilon_0 c = \frac{1}{c}
So, finally
\mu_0 \vec{J} = -\hat z \left(\frac{\mu_0 k}{2c} - \frac{\mu_0 k }{2c}\right) = 0
So
So, finally
I need to find a hole and jump in. I am blind, I was stuck for over a day.
Thanks
Alan
