What is the area of a receiving antennae with an angular spread of θ = λ/d?
  • Thread starter Thread starter Biosyn
    Angular
The discussion revolves around calculating the area of a receiving antenna with an angular spread defined by θ = λ/d, where λ is the wavelength and d is the distance. The provided values are λ = 5*10^-2 m and d = 3*10^3 m, leading to an angular spread calculation. The spatial spread is determined by multiplying the angular spread by the distance the beam travels, resulting in an approximate area of 1 km². However, a more precise calculation suggests the area is closer to 0.54 km², indicating potential errors in the initial assumptions or calculations. The conversation emphasizes the importance of accuracy in deriving the area from the angular spread.
Biosyn
I just have a question on finding the area of a receiving antennae. The answer says the area is about 1km. I got an answer close to 1 km.
λ = 5*10-2 m
d = 3*103 m
The angular spread is θ = λ/d
θ= \frac{5*10<sup>-2</sup>}{3*10<sup>3</sup>}
The spatial spread is the diameter of the beam on the target. So that means it is the angular spread times the distance the beam travels. Correct?
S = r*θ
S = (5*10^7 m ) * θ
S ≈ 1 km The area of the receiving antennae is them [1km / 2 ]2 * ∏ = 0.78km which is about 1 km.
The S ≈ 1 km approximation is rather rough. 830m is closer, and that leads to a final answer of about .54 km2 (note: km2, not km). This suggests you have an error somewhere else, but I'm not qualified to say where.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
