Question on beamsplitter when light is backward-incident
  • Thread starter Thread starter swengzju
    Light
When light hits a beamsplitter with the anti-reflective (AR) coating first, it will behave similarly to when light hits it normally, splitting the light into two paths. One-way transmission is not possible with standard beamsplitters, as this would violate the second law of thermodynamics by reducing entropy. The efficiency of the beamsplitter decreases when used in reverse or at non-standard angles. Therefore, it is crucial to understand that beamsplitters are designed to work effectively in both directions. For optimal performance, use the beamsplitter as intended, with the dielectric coating facing the incoming light.
swengzju
Hi all,
I'm new to this forum and not sure if this is the right place to post this question.
I know that beamsplitters normally have dielectric coating on one side and AR coating on the other side. I'm looking at this plate beamsplitter specifically: https://www.thorlabs.com/NewGroupPage9.cfm?ObjectGroup_ID=4808
I want to know what would happen if light is incident inversely, eg, it hits AR coating first then the dielectric coating. Will I get part of the light going downwards and the rest going through the beamsplitter?
Basically I'm looking for a beamsplitter that only allows on-way transmission.
Any help is greatly appreciated!
Science news on Phys.org
One-way transmission violates the second law of thermodynamics, it would allow to reduce entropy. I don't know how this beamsplitter would behave, but there is no one-way-transmission (neglecting exotic non-linear effects that are not relevant here).
It will work the same both ways around. There are no one-way mirrors.
