Question On Effects of Changing Criteria Of Pulleys
The discussion focuses on the effects of changing criteria of pulleys, specifically the impact of increasing the included angle of the pulley groove and the implications of increased load torque while maintaining constant speed. It is established that increasing the torque results in tighter tensions on both the tight and slack sides of the belt, thereby enhancing the maximum power transmitted. The conversation emphasizes the need for a theoretical understanding rather than just mathematical equations.
  • Understanding of pulley systems and mechanics
  • Familiarity with torque and its effects on belt tension
  • Knowledge of power transmission principles in mechanical systems
  • Basic grasp of V-belt configurations and their applications
  • Research the mechanics of pulley systems and their configurations
  • Study the relationship between torque, tension, and power transmission
  • Explore the effects of pulley groove angles on belt performance
  • Learn about V-belt design and optimization techniques
Mechanical engineers, students studying mechanical systems, and professionals involved in power transmission and pulley design will benefit from this discussion.
Joeyboy1
1.What would be the effect of the following factor on the maximum power that can be transmitted. (give reasons for your answers)
Increasing the included angle of the pulley groove.
2. What would be the effect on the following if the load torque is increased and the speed maintains constant?
The tension in the tight side of the belt
The tension in the slack side of the belt
The power transmitted
I can plug different parts into equations and have gathered that increasing the torque will make both sides of the belt tighter and increase the maximum power transmitted however I can't explain this?
Hi Joe, welcome to PF :)
Please read back your post and put yourself in a helper's position: there's nothing to indicate what this is all about.
Pick up the template once more and try to compose a self-sufficient problem formulation, ... etcetera.
I'll be glad to help out, but give use a chance ! We're not telepathy masters, just simple scientists!
2. Homework Equations
3. The Attempt at a Solution
[/B]
Basically there is a motor driving a pulley linked to another pulley via a v belt. And then that is just asking in theory what effect each has on those parts, there are no formulas to work out it is the actual reasoning behind it of which I don't understand.
They are all self standing questions of which that is all that is given, it's asking for a written answer in theory.
  • · Replies 45 ·
27K
  • · Replies 20 ·
21K
  • · Replies 63 ·
10K
