Question on Reducing Dark Noise in Photodiodes
  • Thread starter Thread starter eNtRopY
    Noise
Reducing dark noise in photodiodes can be approached by cooling the diode to minimize thermally generated hole-electron pairs. The discussion also explores the potential of using a lens to focus illumination on a smaller area, which may enhance the signal-to-noise ratio. Reverse biasing the diode could further mitigate thermal effects, and incorporating resistors may help manage current levels. Manufacturers may provide noise data that could assist in optimizing performance. Overall, various strategies can be employed to address dark noise in photodiodes effectively.
eNtRopY
[SOLVED] Question on Reducing Dark Noise in Photodiodes
I realize that this is more of a technology question than a physics question, but our technology forum seems to have been overrun by computer nerds. Anyway, I am wondering if it is possible to reduce the dark current of a diode by placing a lens in front of it. Let's say that in theory, you could take the illumination normally impinged on a diode of a certain surface area and shrink that same intensity down to a smaller area. Does intensity per unit area affect the dark noise in a photodiode?
Please show me some equations.
Thanks.
eNtRopY
As I remember the dark current is one of the parameters caracterizing a photodiode. So if you want to reduce the dark current you'd have to change the technology in which the photodiode is produced. But I'll take a look at my electronic device course tonight and get back to you.
http://www.ee.bgu.ac.il/~Orly_lab/publictions/OE_Empirical_CMOS_APS_DC_Modeling_Final.pdf
The dark noise
is largely caused by thermally created hole-electron pairs, to reduce them cool the diode.
Great... except your avoiding my question. Can you increase the signal to noise ratio by making the area smaller?
eNtRopY
eNtRopY
Sorry, didn't mean to do that! Sounds probable, maybe the mfr. will supply noise data on the diodes, I'm sure a lot of that stuff is on line now. Also, reverse biasing the diode slightly might reduce the thermal effect. At least it's simple to try it. The result may depend somewhat on whether you using a current or voltage amplifier for the signal.
I know this might sound simple but ever think about adding a 1k resistor in series to reduce its current. better yet, install a variable resistor to limit the current (like an extra intensity button). Just an idea, also don't forget to take into consideration the wattage suppiled don't want you using a 1/4W when you should be using a 1W resistor.
Dx :wink:
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
