Question: Orbital mechanics of a binary star system
The discussion revolves around the orbital mechanics of binary star systems, specifically focusing on the application of Kepler's laws and the two-body problem. Participants explore the mathematical foundations and conceptual understanding necessary for analyzing binary star systems, including the calculation of periods and the dynamics involved in their motion.
  • Some participants mention the two-body problem as a framework for understanding the motion of binary stars, noting that solutions approximate the relative motion of isolated binaries.
  • One participant highlights that Kepler's laws apply to binary systems, suggesting that the motion can be analyzed relative to the center of mass or between the two stars.
  • Another participant emphasizes that Kepler's third law can be adapted for binary systems, where the period and semi-major axis relate to the combined mass of the two stars.
  • There is a discussion about the implications of treating one star as "nailed down" and how this perspective affects the application of Kepler's laws, particularly in terms of energy and angular momentum calculations.
  • One participant points out that the traditional view of orbits being ellipses with a single focus (the more massive body) does not hold for binary systems, where both stars orbit their common center of mass.
  • Another participant introduces the concept of using a reduced mass to simplify calculations in binary star systems, noting that this approach yields accurate total energies and angular momentum.
Participants generally agree on the applicability of Kepler's laws to binary star systems, but there are nuanced discussions about the implications of the two-body problem and the treatment of mass and motion. The discussion remains open with multiple perspectives on how to approach the calculations and conceptual understanding.
Some limitations are noted regarding the assumptions made in applying Kepler's laws to binary systems, particularly the treatment of mass and the simplifications involved in using a reduced mass. The discussion also highlights the complexity of accurately describing the motion of both stars in a binary system.
mathisrad
TL;DR
What are the basic principles/equations for orbital mechanics of a Binary star system?
I was reading about how Sirius A and B were part of a binary star system, im familiar with the concept of binary star systems and even a little bit of how they discovered, as well as spectroscopic and eclipsing binary star systems. However, I still dont know how to calculate period or just general information about binary star systems, as if it was on a test. Is there any set of equations (kindve like keplers laws but for binaries) That I can learn to be more comfortable answering more math based questions on binary star systems? (Also the competition I need to learn this for says its a undergrad level, but I'm posting this in High school physics because I also need to learn the basics, not just the more advanced stuff)
Astronomy news on Phys.org
The motion of two bodies of comparable mass far from other similar masses and far enough away from each other to not have other interactions than gravity, is called the two-body problem and solutions to that should approximate well the relative motion of (isolated) binary star. The geometry of the relative motion for two-body problems are called conic sections since they trace out the intersection between a conic and a plane. The solution even have same "structure" as Kepler orbits, except that the general solution use the so-called reduced mass. So what you know from Kepler's law should also hold approximate true for (isolated) binaries.
Thanks this was really informative
BTW, Jupiter is large enough to treat Sol-Jupiter as a two-body problem. The S-J barycenter is about 49,000km above the Sun's surface.
To shorten the somewhat long and confusing Wikipedia article: yes, binaries obey Kepler´s laws.
About the application: you may follow their movement around the empty and invisible centre of mass - or you may simply follow the movement of star B relative to star A.
Watching the movement relative to (either) star seems to give the simpler solution.
Kepler´s third law is
t2=C*a3/M
where a is the semimajor axis.
For binaries where both bodies have significant masses, the third law still holds if you measure a between the two stars and the M has to be the combined mass of the two components. That simple.
And to add to that, not only does Kepler's third law about the total motion (its period and semimajor axis) apply, so does Kepler's first and second laws! The laws all apply to the motion of the displacement vector between the two bodies (so now we have left high school but you said you wanted more advanced information, the displacement vector is nothing more than an arrow that extends between the two objects, it only has a length and a direction, there's no necessary meaning to where it is anchored). All you have to do is imagine that one body with a gravitational mass equal to the total mass M1 + M2 is "nailed down", and the displacement vector connects it to the other body, moving under that gravity in exactly the way an object would if the other one was not able to move. Indeed, this is precisely the situation where all three Kepler's laws apply.
Digging a little deeper, we should notice that in binary stars, we can't really assume either star is "nailed down" (the way we invariably do for the planets orbiting a "nailed down" Sun, which is the language we use with Kepler's laws in our solar system). Instead, both stars orbit the center of mass, so does this mean our new version of Kepler's law is only approximate, whereas it is accurate in the solar system?
No, all three Kepler's laws still completely apply to the displacement vector between the two bodies. What's more, you can even get total quantities like the potential energy, kinetic energy, and total angular momentum if you imagine that the orbiting body at the outer edge of the displacement vector (the "head" of the arrow, if you will) has a mass equal to the "reduced mass", M1 * M2 / (M1 + M2). Everything is exactly like you were taught about Kepler's laws, except you pretend you have an object of mass M1 * M2 / (M1 + M2) orbiting a nailed-down object of gravitational mass M = M1 + M2. You get right all the total energies and the angular momentum too. The only thing you get wrong is the total momentum, which is not zero for the orbiting reduced-mass object (but of course is zero in the center of mass frame for the real system, so it's obvious you are getting that wrong and wouldn't need to try to use that quantity anyway).
And here's a bonus, you even get one thing right about Kepler's first law that is wrong in the usual way you were taught it. I'll bet you were taught that orbits are ellipses with the Sun at one focus. That's only approximate, and works because the Sun's mass is so much more than the planets (so it's no good for binary stars). As pointed out above, the Sun is not at the focus of the ellipse of Jupiter's orbit, it is the Sun-Jupiter (ignoring all the other planets for simplicity) center of mass that is the focus of both Jupiter's ellipse and the Sun's ellipse (which of course are very close to circles, but didn't have to be). Also, neither of those ellipses have their semimajor axis equal to the maximum distance between the objects. But if you use the description where all you track is the displacement vector between the two stars in the binary (or the Sun and Jupiter), then that vector traces out a single ellipse whose semimajor axis is the maximum distance between the objects, and the "nailed down" hypothetical object really is at one focus, unlike the Sun.
In short, this is actually the situation you have been taught all along, but didn't know it until you started thinking about binary stars.
To dig even deeper, we are always allowed to "nail down" (in effect) one of the objects, simply by choosing a coordinate system where that object is at the origin of the coordinates (which is the only thing that nails it down, it's not something physical just a choice of perspective) and if you do that, these objects with the displacement vector between them are not hypothetical at all. That is not an inertial reference frame (which is why the total momentum is not conserved in that frame), but what we are saying is you can handle all the tricky non-inertial business by completely ignoring it, if you simply treat the object that is nailed down as if it had a gravitational mass of M1 + M2 (and an effectively infinite inertial mass, as it's nailed down by the coordinates), and the object that is orbiting as if it had a gravitational and inertial mass of M1 * M2 / (M1 + M2). This is a wonderful simplification of the two-body problem, and it works for any M1 and M2. As mentioned, you even get the total energies and angular momentum right, which is quite convenient.
  • · Replies 0 ·
