p75213
- 93
I have a cylinder wound with string. The free end of the string has a weight dangling from it. Is the tension in the string simply mass of the weight*gravity?
No, not if the mass is accelerating.p75213 said:I have a cylinder wound with string. The free end of the string has a weight dangling from it. Is the tension in the string simply mass of the weight*gravity?
Some points:p75213 said:That's the worked solution. Now let's look at T - equation (a)
T-49=2.5*alpha
T=2.5*alpha+49
T=100.6N
I would have thought T was equal to mg=5*9.8=49N
Doc Al said:Some points:
(1) Redo your solution as you've made an error. You have the tension greater than the weight of the hanging mass. That would mean the mass rises instead of falls!
(2) If the tension equaled mg, then the hanging mass would be in equilibrium.
(3) You can check your work by solving the problem using energy methods.
