Questions about Communication Protocols
  • Thread starter Thread starter F.ono
    Communication
The discussion centers on the challenges faced by a project engineer in understanding communication protocols for electrical equipment in substations, specifically Modbus, Profibus, and IEC-61850. Key questions include the appropriate types of connectors (RS232, RS485, DB9) and cables (fiber optic, twisted pair) needed for various applications. The importance of historical choices by manufacturers, such as the use of DB9 connectors, is highlighted as a complicating factor. Suggestions for further learning include exploring summary pages and reference links on these protocols, particularly on Wikipedia. Gaining a clearer understanding of these communication protocols is essential for effective project execution.
F.ono
I work as a project engineer of electrical equipment for substations.
More and more I have to deal with the communication of these equipment with PLC and other equipments. But I really don't know much about this area.
For example, we have Modbus, Profibus, IEC-61850... every now and then I have to verify if we have the components required to connect some equipment to some network.
So the following questions arise:
- What type of connector do I need? When do I use RS232, RS485, DB9, etc?
- What type of cable do I need? When do I use fiber optic, twisted pair or whatever?
I have searched and read parts of books about it, but they don't really get straight to the point.
I would really appreaciate if someone could give me an introduction about it.
Your answers depend on the bandwidth and environmental requirements, and more important on the historical accidents of convention. RS232 for example, has been implemented with dozens of connector and cable combinations.
An "accident" might be that a manufacturer chose to use DB9 connectors. You have to accommodate that even if he had no good reason for choosing DB9 over alternatives.
I'm afraid that my answer amounts to no answer of your question.
I googled Modbus, Profibus, IEC-61850, and got some good hits on summary pages. I'd suggest reading through some of them, and following some of the reference links at the Wikipedia pages. That should start to give you a better understanding. If you have specific questions about that reading, please do post them here so we can help out. :-)
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
