Questions on basic differential equations
danield
Well this is my first diff eqs homework and I am totally lost, i have no idea what to do here are teh questions that i have...
1)An object released from a height h meters above the gorund with a veritcal velocity of Vo m/s htis teh ground after To seconds. Neglecting fricitonal forces set up and solve the inital value problem governing the motion and use your solution to show that...
Vo=(2h-gto^2)/(2To)
2) Determine a solution to the differential equation
(1-x^2)y'' - xy' +4y = 0
of the form Y(x) = a0 + a1x + a2x^2 satisfying the normalization condition y(1) = 1
3) Determine the differntial equaiton giving the slope of teh tangent line at teh point (x,y) for the given curve
x^2 + y^2 = 2cx
1)on that one i got till the point where i have
1/2gt^2 + C1t+ c2 = y(t)
2) On this one i have no idea how to start maybe help on where to start will be enough...
3) on this one i also have no idea where to start...
im still working on other ones ill see if I am able to work them out
any help is appreciated
thanks
Vo=(2h-gto^2)/(2To)
x^2 + y^2 = 2cx
Okay, you know that y(0)= (1/2)g(0^2)+ C1(0)+ C2= h (An object released from a height h meters above the ground) and that y'(0)= g(0)+ C1= V0 (with a vertical velocity of Vo) so you can determine C1 and C2 from those.
Do it! You are asked for a solution of the form y= a_0+ a_1x+ a_2x^2 so y'= a_1+ 2a_2x and y"= 2a_2. Put those into the differential equation and solve for a_0, a_1, and a_2 by, for example, choosing three values for x to get three equations.
You have a "family" of curves given by x^2+ y^2= 2cx and you want an equation involving y' and/or y" but not c. Now, you could just differentiate with respect to x twice and that would eliminate c: 2x+ 2y y'= 2c and then 2+ 2(y')^2+ 2y y"= 0. But since there is only one "c" you should be able to do this with just one differentiation. Differentiating once gives 2x+ 2y y'= 2c so c= x+ y y'. Replace c in x^2+ y^2= 2cx with that!
thanks
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
