Questions regarding rotational motion
The problem involves a computer disk with a diameter of 8.0 cm that accelerates to a specific angular velocity and then coasts. The original poster seeks to determine the angular position of a reference dot on the disk after a total time of 1 second, given the disk's acceleration and angular velocity.
  • Mixed
  • Participants discuss breaking the motion into two parts: the accelerated phase and the constant speed phase. There is a suggestion that different formulas may apply to each segment of the motion. Some participants express uncertainty about the original poster's approach and seek clarification on the reasoning behind the formulas used.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the application of rotational motion formulas, but there is no explicit consensus on the correct approach or solution at this time.
There is a mention of potential confusion regarding the application of rotational versus linear motion equations, and some participants question the correctness of the original poster's calculations and assumptions.
dismalice
A computer disk is 8.0 cm in diameter. A reference dot on the edge of the disk is initially located at The disk accelerates steadily for 0.50 s, reaching 2000 rpm, then coasts at steady angular velocity for another 0.50 s.
I have found that a_t=17 m/s^2 @ .25s
a_c = 440 m/s^2 @ .25s
and v = 8.4 m/s @ 1s
I need to find the angular position of the reference dot @ t=1s
Theta = Theta(not) + (Alpha T^2)/2
s=rTheta
Alpha= dW/dT = 2000 (2pi/60) = 209.44 rad/s
Theta= 0+ ((alpha)t^2)/2) + (alpha*t^2) = 314.16 rad
I think you have to do it in two parts.
First the accelerated part, then the constant speed part.
No one formula applies to the whole motion.
Could you please give me an example, I am not quite clear on what you are saying.
For the first .5 seconds, it is accelerated, so use your
Oops, I don't think that is quite right - better look it up.
I think the rotational formulas are analagous to the linear ones, so think
D = V1*t + ½ at²
and change the D to θ, the V1 to ω1, the a to alpha.
The formula for the second part will be analgous to d = vt.
  • · Replies 24 ·
