What Happens to Light Speed After Passing Through Glass?
  • Thread starter Thread starter ccf788
    Mirrors
When light passes through a block of glass and exits into the same medium (air), its speed returns to that of air, which is the same as before it entered the glass. The discussion clarifies that while light slows down in glass, it resumes its original speed upon re-entering air. The consensus is that the correct answer to the light speed question is that its speed is the same as that before it entered the glass. Additionally, for the concave mirror question, the answer is confirmed to be 'a', as placing the face inside the focal point produces an enlarged, virtual image. Understanding these principles is essential for grasping the behavior of light in different mediums.
ccf788
A light ray in air enters and passes through a square block of glass. What can be stated with regard to its speed after it emerges from the block?
a) Its speed is less than when in glass
b) Its speed is less than before it entered glass
c) Its speed is same as that in glass
d) Its speed is same as that before it entered glass
and
In order to see a huge right-side-up image of yourself, you should use a concave mirror and place your face:
a)inside the focal point
b)at the focal point
c)between the focal point and twice the focal poing
d)at twice the focal point
e)beyond twice the focal point
I think the answer to this one is a, but I am not positive.
Please help!
I'd have to say the answer to the first one is 'b' since the speed of light is constant(for the material that it is in) and if both sides of the block are the same material, like air, then the speed will be the same on either side.
For the second one, the answer is a. It will be an enlarged, virtual, image. Here's an article to help explain what goes on with images in a concave mirror. http://www.physicsclassroom.com/Class/refln/U13L3e.html
Light, in a vacuum, travels at just under 3 x 108ms-1. As soon as a medium is put in the way, its speed decreases. It may not be by a lot but you can see the difference when it enters a glass block, as it appears to 'bend' the light. The speed of light in the same medium is the same and the answer is not 'b'.[/color]
So, if the medium is the same on the exit side of the block as on the enterance side of the block (e.g. it travels in air before and after it is in the glass block), what do you think we can say? Remember, light in the same medium is the same speed.
The Bob (2004 ©)
So I don't think you mean "b".
So would its speed be the same as that in glass or would its speed be the same as that before it entered glass? I'm still confused.
Let me quote myself:
:-p
To the question:
So you have narrowed it down to the same speed as in the glass block or the speed before it enters the glass block. Well when the light comes out of the block it enters a medium. What is this medium?? When was it last in this medium??
The Bob (2004 ©)
