Is Measuring Bubbles a Reliable Method for Determining Carbonic Acid Levels?
  • Thread starter Thread starter nibbel11
    Acid Chemistry
Researching carbonic acid in fizzy drinks involves understanding the equilibrium between dissolved CO2 and carbonic acid (H2CO3), which can dissociate into water and CO2 or into hydrogen ions and bicarbonate. The measurement of CO2 bubbles released from a drink can provide insights, but it is crucial to define what is meant by "amount of carbonic acid," as it encompasses various forms including dissolved CO2, H2CO3, bicarbonate (HCO3-), and carbonate (CO32-), all influenced by pH and atmospheric CO2 pressure. While measuring the amount of bubbles lost is a valid approach, it should not be directly equated with the amount of carbonic acid. Instead, quantifying in moles or grams per liter is recommended for clarity.
nibbel11
Hello everyone
I am doing some research about carbonic acid in fizzy drinks. I hope to find out how much carbonic acid was in the drink by looking how much CO2 bubbles come loose. but later I thought that there are two reactions that can take place:
H2CO3 --> H2O + CO2
H2CO3 --> H+ + HCO3-
because both of these can take place does my plan still work, if not is there another way to find out how much is in the drink.
Chemistry news on Phys.org
"How much carbonic acid" is a bit ambiguous, as it depends on what you mean by that.
Solutions contain dissolved CO2 in equilibrium with H2CO2 (and the ratio between these two is rather difficult to measure, so we typically treat them as a single entity), plus - depending on pH - different amounts of HCO3- and CO32-. To make things even more difficult, amount of CO2 that the solution can release depends on the partial pressure of CO2 in the atmosphere above.
Your definition of "how much carbonic acid" must take all these into account.
"Amount of bubbles lost by the drink" is a well defined (or rather - can be well defined, when you unambiguously describe how it is measured) property of a drink, so measuring it is a reasonable thing to do. Just don't call it "amount of carbonic acid".
Maybe you should measure in moles per litre.
Or grams per litre.
alright thank you
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
