Earth's Elliptical Path: Acceleration Direction Explained
  • Thread starter Thread starter alexmahone
    Ellipse
The Earth follows an elliptical orbit with the sun at one focus, raising questions about the direction of its acceleration. While initial calculations suggested that acceleration points toward the center of the ellipse, the gravitational force from the sun indicates it should actually be directed toward the sun. Acknowledgment of incorrect parameterization highlights that the speed of the Earth varies, being faster at perihelion than at aphelion. The discussion also shifts to a general case of particle motion, emphasizing the importance of analyzing second derivatives to determine acceleration direction. Ultimately, the acceleration of the Earth is indeed directed toward the sun due to gravitational influence.
alexmahone
The Earth travels in an elliptical path with the sun at one of its foci. Is the acceleration of the Earth directed towards the sun or towards the centre of the ellipse?
The Earth's elliptical path can be parametrized as:
x=acos (pt)
y=bsin (pt)
Using the above parametrizations and differentiating twice, I get that the Earth's acceleration is directed towards the centre of the ellipse.
However the force on the Earth is due to the sun, and so I feel the Earth's acceleration must be directed towards the sun.
Please help.
That's correct.
EDIT: you're paramaterization is incorrect if "t" is really the time. It implies the speed is the same at aphelion and perihelion, but in reality it is faster at perihelion.
Redbelly98 said:
That's correct.
Thanks, Redbelly98! :)
Forget the Earth - sun example.
What if the x and y coordinates of a particle were given by the parametrization where t is time? Where would the acceleration of the particle be directed towards?
That's a reasonable question. Well, you can take the 2nd derivative of both x and y with respect to t, and see what direction the vector
a = (d2x/dt2, d2y/dt2)
points in.
