Quick question on explaining the law of conservation of momentum.
The discussion centers on the law of conservation of momentum in the context of a space vehicle and its booster unit separated by an explosion. The user has successfully calculated the impulse on the space vehicle but seeks to demonstrate that the impulse on the booster unit is equal in magnitude and opposite in direction. The explanation emphasizes Newton's third law, stating that the forces between the two bodies are equal and opposite, leading to a net momentum change of zero in the closed system. The time given in the problem is relevant for calculating impulse, reinforcing that the overall change in momentum remains conserved. The conversation concludes with an acknowledgment of the helpfulness of the explanation provided.
Senjai
I have done the question already and attained the correct answer. However if it was a written question i do not know how i could prove the following.
A 7.3 x 10^3 kg space vehicle and its empty 6.8 x 10^2 booster unit are moving together through space at 370 m/s. An explosion lasting 2.2s is used to separate the two parts. If the speed of the space vehicle is increased to 430 m/s, what impulse acted on the booster unit?
I used the Impulse formula I_{space vehicle} = \Delta{p}
And used the change of momentum of the space vehicle to determine the Impulse exerted on it. How would i prove that this impulse is the same in magnitude and opposite in direction as the impulse exerted on the booster unit?
Is their a way to do this question a different way? Did they give the time for no reason?
Regards, Senjai.
The space vehicle, the booster unit together with the explosive constitute a closed system in the far space. Only forces of interaction act among them. According to Newton's third law, if a body "1" acts with force F12 on an other body "2" this other one acts with force F21=-F12 force on the first one.
The momentum is I=F\Delta t. The sum of the forces of interaction is F12+F21=0, therefore I=F_{12}\Delta t+F_{21}\Delta t=0 \rightarrow I_1+I_2=0
The change of momentum is equal to the impulse. When only two bodies are interacting \Delta p_1+\Delta p_2=0
The sum of forces in a closed system is 0. So is the overall change of momentum.
The vehicle and booster are separated by an explosion, but we can assume that no momentum is wasted, or this waste (the momentum of escaping particles of the explosive) is negligible -we have only two interacting bodies.
ehild
Thank you so much :P Appreciate it :)
