How Do I Derive the Specific Thermal Diffusion Equation?
bon
Please see question attached..
Not sure how to go about the derivation..
I know the general derivation of the thermal diffusion equation where we imagine a surface S bounding a volume V, then integral of J.dS = d/dt integral over volume of CT dV
So using divergence theorem, the thermal diffusion equation pops out..
But how do i derive the equation here?
the heat flux isn't really across a surface..im a bit confused :S
Thanks!
*bump*
You can derive that equation from the heat equation. Just cancel out terms in the equation that don't apply. He/she tells you to assume the plates are copper rods, so that's why the laplacian is only in the x direction. In the heat equation there is an accumulation term, a convection term, a conduction term, and a removal or generation term. I don't think you need the convection term here unless you want to add in a fan or something. See my attachment.
Sorry I still don't understand how to derive the first part of the question.. Any help would be greatt
where does the 2/a come from?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
