Quotient & Product Rule: Same funtion, different answers?
AntSC
Can someone check my working. I don't understand why i am getting different answers?
u(x,t)=\frac{{e}^{-\frac{x^2}{4Dt}}}{\sqrt{4Dt}}
Differentiate w.r.t 't' by quotient rule:
\frac{\partial u}{\partial t}=\left[ \frac{1}{\sqrt{4Dt}}\cdot \frac{x^2}{4Dt^2}\cdot {e}^{-\frac{x^2}{4Dt}}-{e}^{-\frac{x^2}{4Dt}}\cdot \frac{1}{\sqrt{4D}}\cdot \frac{-1}{2t\sqrt{t}} \right]\frac{1}{4Dt}
\frac{\partial u}{\partial t}=\left[ \frac{x^2}{4Dt^2}u(x,t)+\frac{1}{2t}u(x,t)\right]\frac{1}{4Dt}
For the product rule, write as -
u(x,t)={\left(4D \right)}^{-\frac{1}{2}}{t}^{-\frac{1}{2}}{e}^{-\frac{x^2}{4Dt}}
Differentiate w.r.t 't' by product rule:
\frac{\partial u}{\partial t}=\frac{1}{\sqrt{4D}}\left[ {e}^{-\frac{x^2}{4Dt}}\cdot \frac{-1}{2t\sqrt{t}}+\frac{1}{\sqrt{t}}\cdot \frac{x^2}{4Dt^2}\cdot {e}^{-\frac{x^2}{4Dt}} \right]
\frac{\partial u}{\partial t}=\frac{x^2}{4Dt^2}u(x,t)-\frac{1}{2t}u(x,t)
This is clearly not the same.
What am i doing wrong?
You didn't use the quotient rule correctly. Denoting ##u(x,t)=\frac{v(x,t)}{w(t)}## where ##v(x,t)=\exp\left(\frac {-x^2}{4Dt}\right)## and ##w(t)=\sqrt{4Dt}##, then the quotient rule says
$$\frac{\partial u(x,t)}{\partial t} = \frac{\frac{\partial v(x,t)}{\partial t}w(t) - v(x,t)\frac{\partial w(t)}{\partial t}}{w(t)^2}$$
The terms you wrote for v(x,t) and w(t) is what i chose for the quotient rule. The w(t)^2 is the \frac {1}{4Dt} term outside the brackets.
I don't see what am i missing?
You did a couple of things wrong. You computed ##\frac{d}{dt}\sqrt{4Dt}## incorrectly, and you lost a radical term somewhere along the line in your quotient rule computations.
I've spotted my stupid mistake. Thanks for the pointer. I've been going round in circles with this.
Cheers
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
