Race car suspension Class
1,812 replies · 942K views · last reply
Wylde said:
Just out of curiosity, does any car on asphalt use a lift arm rather than a pull bar for their 3rd link?
It is very commonly used in Tour-type Modifieds in the Northeast. They are commonly referred to as a Torque Arm. Depending on the car manufacturer and the driver preference they are mounted on ether side off the rear end.I have one on the car we recently purchased.
drobbie you haven't raced with it yet? I looked at the Neuline at PRI and it looked pretty interesting as far as adjustability
Not in this car. I have in the past when I crewed for several NASCAR Whelen Modified teams. The ones we use have a rod end attach to the chassis and a rubber biscuit to absorb the shock under acceleration and deceleration.
So what is your take on them? Thw Whelen Mods seems to be high horsepower with big sticky tires. My application is small hard tires and much lower horsepoer.
I think they can be very effective if they are set up right. Just like a pull bar, you need ensure its positioned left to right correctly, has the right amount of wrap up, etc. One of the things I think it does excel in is if you adjust the length you can increase or decrease the amount of effect it has lifting the chassis.
You guys are really making me work this week!
I had to go to the hauler and dig out Short Track Chassis Set up by Duke Southard to get the third link low down. See attached pic - Note the use of the pull rod and rubber donut to tune in acceleration You must use a damper ( in this case coil over shock) to limit brake hop with this setup. This set up is for really big gummy slicks when you have big horsepower to use up. It looks like what you found under the old Gassers and Altered at the drag strip. Max traction but they did not worry about wheel hop since they had a parachute.
In our situation we have hard spec tires and somewhat limited horsepower compared to a full blown Modified or Sprint Car.
Let us understand what happens to the rear tires when cornering. Please look and study post # 1126 page 57. The tire contact patch at 0 slip angle to 8 degree slip angle. A we go over 8 degree slip angle we lose traction and spin out.
A no rear steer car will have its rear tires go into shear ( where the contact patch adhesion is less than the slippage area) quicker than a race car set up to have rear roll over steer.
As I said before the dirt track super late models run huge rear roll over steer. Watch or look at a photo of one of these beasts at turn entry. The left rear wheel axle center cover is almost at front of the sheet metal wheel well. The left side wheel base shrunk up as the right side wheel base grew.
Now paved track cars do not use a lot of this for to do so would quickly burn off the rear tires.
The typical set up on a 3 link rear end set up is to have both bottom links ( trailing arms) equal length and running up hill by 5 degrees. This cranks in about 1/4 to 1/2 inch wheel base change.Herb Adams wrote in his book Chassis Engineering that you can set up the rear end to angle to the left ( inside of the track) and adjust the trail arms to take way the induced under steer. See trail arms per attached pic below. I personally have under steer in any way shape or form so am just making you aware of this. Get his book and explore it if you like.
This brings us to the 3rd link. I noted above in post # 1168 page 59 about the 3rd link.
Please read these and the mount location is critical to get equal loading on both tires. As mentioned we once ran a 3rd link that ended at he drives gas pedal.
Spring link and rubber biscuit setups are supposed to ease tire shock when you mash the go pedal. True but there is a more important factor that is not apparent.
The race car goes into the turn and the body rolls causing the wheel base to grow on the right side. As the car accelerates the body settles and the roll over steer goes away.
The cushion rubber grommet or spring top connector bar maintains this roll over steer a tad bit longer than a solid non cushion top link. You stay in roll over steer a little bit longer.
Your tires maintain more tire contact than the less roll over steer car so you are hooked up and moving.
Small advantage but races are won on smaller things..savvy?
  • Hand-drawn diagram of a race car rear suspension titled 5th COIL - OVER / TORQUE ARM ARRANGEMENT, showing a 36 inch torque arm, a coil-over shock and a 13 1/2 inch static ride height.
  • Diagram titled Arms set for understeer out of a corner and oversteer into a corner, showing left and right control arms converging on a circle representing a rear axle.
That makes sense to me Mike. I have repositioned my 3rd link mounting to take into account the mass percentage and after reading all the material I discovered I ran way too much angle.
All you guys get the credit Mike. I had over 20 degrees of angle in the 3rd link
20 degrees? Sounds like you were running dirt not asphalt!
An old engineer I used to race against ran modifieds for a long time in the 90's and 2000's (Him and I had a pretty good rivalry on the track but were great friends off track). This was when 3 link modifieds were still the hot ticket in our area at least. One day he was telling me that he used to run the right side trailing arms flat or even downhill when the track got really slick. From your second picture and the annotation under it, there was a statement saying if you can dial in roll over steer on entry and roll under steer on exit that's where it is fastest. This makes a lot more sense now why he would run a downhill angle on the rr trailing arm. I might have to try that out on my dad's B-Mod to see what exactly it does.
Thanks for the info RM. Glad we can keep you busy during this gloomy winter!
Yes Wylde I got caught up in the monkey see monkey do game. It wasn't until I started reading the pages here that I realized how many things I didn't understand about setup. I'm very excited for the start of the season because I will have a new car handling wise compared to last season!
Just finished up modeling my RC for my dirt late model. Numbers seem odd compared to what I have read in the forum, but I have remeasured them a few different ways and they repeat. Secondly I measured camber in the model and it is spot on to the actual measurement. Take a look at the picture and see what y'all think. http://imgur.com/a/VbWel
smever. what software program is this? The Roll center height looks to be about 3.125" height, but too much to the right .. looks to be about twice the typical offset.
I am subscribed to this thread.
60 pages of wisdom and real world theory!
Can't thank you guys enough!
I built this in solidworks. It took a little while now configurable model. Next I will try to find the rear and get both in the same 3D sketch. So my RC height should be around 3" from the ground and 4" right of CL?
Ranger Mike I have a small splined sway bar that I am going to use on my car. It will contact the bottom of the axle on the left side and I plan on using an adjuster on the right side to tighten it. Because of the right side shock location I was thinking of mounting the adjuster to the backside of the axle but this would effectively make the right arm shorter. What are your thoughts on this?
Back in the 1960s I was crewing on a Ford team. No one was running ARBs then. I was devouring every car magazine I could glom onto. We picked up a pick up truck ARB (sway bar) and mounted it to the top frame hoop rail that ran from the firewall to front end over the radiator and back to the fire wall. Same rail the shocks mounted to. We cobbled up a couple of links to run down and attach to the top A-Arms. Worked real good.
Is your set up going to be perfect..no...but I can tell you it will work.
All things being relative, the ARB will cut down body roll and you can go softer on the front springs, lower the car a little and pick up maybe a second quicker lap time. Go for it.
Its only .550 so I can't load it too much. I just want to be able to tighten the car on exit if needed.
I would say that ALL racers are pretty much a focused group of people working on a cold garage floor in the middle of January in a thankless effort to make a car of questionable merit just a little bit more competitive . Some days we get too focused to worry about the mortgage, wifes birthday let alone anniversary , mowing the lawn, let alone world hunger, politic ...case in point
see attached pic...says it all
  • Meme with two photos of women at top: left, a blonde woman says OMG! TRUMP IS GREAT; right, a woman screams with hands on her head, OMG! TRUMP IS EVIL. Bottom: a car drifting on a track, captioned AND I'M OVERE HERE LIKE WHY WONT THIS P.O.S TURN?!?!
I have a couple of questions about our asphalt modified that we race in the Northeast. We have put the car on a diet and taken off approximately 60 pounds which we will have to add back on. We can have 56% left side. Should we strive for a 50% nose and 50% rear?
The other question is coil bind? I think I read somewhere that when you take off your coil-overs the spring should be loose, or at least able to turn with the shock extended? I am assuming the spring would be set at ride height too? If it is true what do we do? Thanks !
Welcome and thanks for the kind words
Front to rear weight 50 50 split is ideal. Ifin you can go 52% rear this is optimum.
The reason you want loose springs on the coil overs is repeatability of your setup.
We always had the Shock gods rebuild and dyno our Penske 3 way shocks. We had loose rear springs and the front was teched out with internal droop limiters so they had many turns preload on them.
We were told never to mess with the set up. We never did and won many championships in the Division. One thing we did use religiously was the hyperco spring perch's that would articulate and really reduced coil bind.
http://www.hypercoils.com/perchesno cheap to buy but when you think about it, it is the cheapest way to cut lap times by 1/2 second.
Wow.. I just made it thru most of the 60 pages.
Amazing info here!
You guys really show your expirence!
Thanks for everything.
One thing I would like to bring into discussion that I didn't see was the old thoughts of high castor for numbers for helping transfer weight on the 3200 lb stock cars.
My stock car was prolly by far the best handling car I've ever been in.
But on to the castor trick a wise man taught me..
Positive castor drives right spindle up and lowers cross while turning in. And in same effect when turning in it also drives left spindle down further lowering cross. Basically loosening car by simply driving in.
And as you start to straighten the wheel back out it brings cross back into right side tightening car back up to get amazing bite on exit.
By positive caster, I mean way positive..
it ran +7 on left front and +9 on right front.
This car ran best w 3-3 left front and a 5-5 on right front. And 4-4s across the rear.
We had to run steel body hydraulic Shocks in stock location.
Cheap but very effective on this setup.
This car stayed flat as a pancake in the corner but transferred weight like no other. Weight transfer is the easiest traction when working properly.
Ranger Mike and others... trying to make your minds turn a bit
What's your take on this? And why hasn't anyone brought this setup up?
Caster is usually split from left side and right side. by this I mean the right side caster is 2 to 3 degree larger than the left. Done correctly, the race car will turn itself in a turn. Power steering cars can run more caster. caster will build up your fore arms to look like Popeye the sailor if you want to go there.
Caster lifts the right front of the car by rotating the king pin angle causing the wheel to drive into the ground and lift the chassis. When doing so, it adds wedge to the left rear tire. Next time you scale a car read the left rear scale, then turn the steering wheel left and take a look. Left rear weight goes up but not much. When you run positive caster on the left front on a dirt car, when you counter steer, it adds wedge to the right rear tire and helps drive off the turn.
caster does not take away cross weight ( wedge).
Dirtracer did you adjust your static cross weight down because of what was added dynamically by the higher caster?
We set the car up like normal.
Mike is right, it didn't add cross.
When you turned in it de-wedged the car. And you turned straighter it wedged it back up. And if i had to over correct, it went even tighter which helps catch the rear end of car.
This set up was from a ole timer that ran stocks . I was distilled into my car ,
IT WORKED.
That car won 16 of the 19 nights I ran it.
Ok I misunderstood. Always read something twice before opening my mouth is a rule I sometimes forget.
you guys are not making life easy for the old ranger...now i got to slug out to the race car hauler and dig out my dirt track set up notes and start writin about rear steering and the whole thing..after i stop and get some beer..check back later ..you dirt racers may like it
By no means am I a dirt track guy as you can spend your whole life studying tracks and such and still not hit on the right set up. Dirt racing is a black art and as much art as it is science. I have a hard-enough time getting things right on pavement so will just put in my two cents here.On Dirt, you do not want any rear roll over steer on a wet, tacky track. On hard packed dirt, yes, dial it in. That is why I recommend you know the chassis settings at ride height for zero roll steer, max roll over steer and a few settings in between.
4-Link Suspension systems use a Bird cage on each side of the axel that rotates around the axel tube. These bird cages have a top and bottom mount that mount radius rods to the chassis. Usually these are front facing as the pic depicts. Coil overs (sliders in some cases) are then mounted to the bird cage bottom mount on one side and dampers (shocks) are mounted to the back side of the mount. Sometimes the bottom mount attaches to a swing arm (Z link). We will study the more popular 4 Link suspension.
It became popular on dirt due to the ability to angle the top links upward where they attach to the frame mounts and use the tire thrust to load the tires. Any time the link is mounted uphill to the frame and the rear mount is downhill on the axel, the rear end will try to run under the chassis. This will load the tire bigtime. We have axel thrust.
Originally, these 4 links were designed to minimize rear steer during chassis roll. About 20 years ago, we wanted zero change in the wheel base as it was thought that this provided the most stable handling situation. Although it was thought that a small amount of rear roll steer would assist in turning the car but excessive amounts of roll rear steer was to be avoided.
Typical settings on 4-link was upper right link at 17° up hill,
upper left link at 13° uphill,
Both bottom links at 5° downhill.
This set up would add ¼ inch right side wheel base and reduce left side wheel base by ½” for ¾ inch rear over steer. Hardly noticeable.
As with anything having to do with fast cars, young women, and old whiskey, it was not long before some wild man started running more rear roll over steer than the next guy and now we have insane gobs of wheel base change and all kinds of body twist and shout!
Wild…
Now the wheel base changes up to 4 or more inches and we have link settings like
Typical settings on 4-link was upper right link at 18° up hill,
upper left link at 22° uphill,
Left bottom links at 5° Uphill. Right bottom level to the ground.
But a picture is worth me typing 1000 words and even more fun is watching this action.
This is rear over steer in action - Jake Bridge-Left rear dirt late model
2008 Hoffman Dirt Modified 4 link Rear Suspension with sliders torque link /damper
E-Mod on dirt Matt Stagman Rear Suspension Cam
Why you had better have that torque link and damper properly mounted
Modified 4 link camera on right rear. Cool index of bird cage. Tie down that brake hose!
Passmore Racing Dirt Late Model Torque Arm Video
I could watch this stuff all day...
  • Diagram of a 4-link rear suspension bird cage on a car axle, with a tire at right, numbered mounts 1 to 4 on the cage, and arrows showing the link forces.
  • Diagram titled Suggested Baseline 4-Link Angles showing left rear and right rear suspension links; left upper link 20 to 22 degrees uphill, left lower link 5 to 7 degrees uphill, right upper link 16 to 18 degrees uphill.
