mfb said:
There are many free parameters, and the answer will depend on your choice which parameters you want to fix in which way.
We should change the title to (" ... More or less rate of KE change") as we know the heavier car will always end up with more KE, but not as much as it's weight change would appear to indicate.
Well, let's start with the fact that a heavier car with the same HP as the lighter car, will accelerate to a slower top speed for given distance.. (say to the point at which both cars need to engage the brakes to slow to get to turn in speed for the next turn)
General parameters:
3000lbs car (1363.6 kg) vs 3500lb car (1666 kg)
both launch onto the straight at 45mph (20.1 m/s)
Heavy car reaches 114mph (50.9mps) before braking at the same spot at initial braking point,
light car reaches 120mph (53.6mps) before braking at the same spot at initial braking point.
note: i ran the cars through a simulator to get these speeds, complete with engine torque curves, drag values, grip and geometry equivilance.
I also made the assumption that the tires would give the same g's of deceleration for both cars. assuming that the 3000lb car could decelerate at 1g, was first thinking that the heavier car, with no changes to tires, would slow at 15% slower speed for the 15% higher mass.
Many think that the heavier car is intuitively harder on the brakes. in other words, does a race car that suddenly takes on a 500lb guy as a passenger, have to worry more or less about brakes?
since the simulation takes the lighter of the two cars to about 5 % higher speed,, it has about 5% less KE as well. since the heavy car will decel at 15% less of a rate (.85g vs 1g) the rate of decel being greater for the lighter car gives it about 3.-4% more KE to dissipate. per second.. thus being harder on the brakes, not easier.
some then say, well,if the heavier car slows to a lower speed, say 30mph (13.4m/s) vs 33mph, (14.7m/s) then it will dissipate even more KE. .. True, but the rate of KE dissipation goes down even further. just comparing .85g for heavier car's distance that both would cover in 4.3seconds vs 4 seconds ((that's the time comparison for both masses to slow from their respective speeds to the final speed in their respective g deceleration rate) it would go to 4.5 seconds . this actually lowers the power/second of the heavier car's deceleration KE dissipation. by the way, the distances that both cars stop at , is within 10ft of each other... (in this simulation both cars got to 1840ft before braking and then i calculated the distance they would slow to the same target speed based on their g value of deceleration.
Let me know if I've missed anything here
If what I have run in the above simulation is true, then the thing that i think can change everything is the assumption that the tires of both the heavy vs light car, have the same deceleration force to the ground. there are limits to the tires ability in the way of slip percentage do to the deformation of the rubber on the surface, giving the mu for friction coefficient. but I've heard that there is some maximum force that the tires can apply, and if we found that with the lighter car, then the heavier car couldn't create any more force at the tire,even with more mass.
and if that is true, then, what if the car is lightened to half its weight again... can it impose the same force of deceleration as it did when it weighed 3000lbs? if it weighted 6000lbs?
The same scenareo, with the KE values attached:
Two cars , CAR A (light car at 3000lbs) vs Car B (heavy car 500lbs heavier at 3500lbs). two cars with the same HP are running:
car A 120mph (53.64 m/s)
car B 114mph (50.9 m/s)
the simple part of this example is that we can just plug in the numbers if we agree that the heavy car will slow at 15% less deceleration rate. we will call this 1g vs .85g respectively . (need to confim if this is a real possibility, or does the deceleration force go up proportional to weight?) for the sake of argument, let's assume that the heavier car breaks at a lower rate due to tire limitations.
This means in 4 seconds the light car slows to 33mph (15m/s)
this also means in 4.3 seconds, the HEAVY car slows to the same speed
keeping it really simple. the KE at the start is:
1,991956 J Light
2,085,914 J Heavy
the KE at the end at the final same exact speed is:
153,405 J
178,977 J
this ends up with the lighter car dissipating a total of 1,838,551 for the light car
and 1,906,937 J for the Heavy car. heavy car dissipates more energy by 3.7%
BUT
Because the lighter car slows to the same speed in 4 seconds and the heavy car slows to this same speed in 4.3 seconds, the RATE OF KE DISSIPATION is HIGHER for the ligher car by about 3.7%
616HP/sec for the light car ( example : 1,838,551 J /4 sec /746watt =hp/sec)
594HP/sec for the heavy car ( example : 1,906,937 J /4.3 sec /746watt =hp/sec)
the rate of heat dissipation for the light car is HIGHER than the heavy car for its decel rate and its higher speed at the moment of braking (at the same spot on the track)
Therefore, this shows that adding weight, under these normal conditions, actually lessens the burden on the braking system.
