Rack and pinion in an Ultra-High Vacuum
  • Thread starter Thread starter LaunyO
    Vacuum
The discussion centers on the feasibility of using a rack and pinion mechanism in ultra-high vacuum (UHV) environments, particularly in confined spaces under 10 mm. Participants express concerns about potential issues like air blockage, out-gassing from materials, and the need for non-magnetic components. Recommendations include using brass or beryllium copper instead of stainless steel due to its magnetic properties. The vacuum levels discussed range from 10^-7 Pa to 10^-9 Pa, with suggestions to consult NASA or cube-sat resources for material compatibility. The conversation emphasizes the importance of material choice and lubrication in UHV applications.
LaunyO
TL;DR Summary
Rack and pinion mechanism in UHV
Hi everybody, I have a question with no clear answer so far.
Does the rack and pinion mechanism work in UHV ?
I have to translate an object in very confined scace (less than 10 mm), all in UHV.
Any response is welcome :)
1) How are you going to get a rack and pinion into 10mm ? Might be possible (I'm not familiar w/ micro-machines) but seems unlikely.
2) I see no reason why it would not work in a less confined space. Presumably the drive mechanism would have a sealed lubrication system.
3) What does "translation" mean in this context?
Likes LaunyO
Presumably the pinion is in a region of rougher vacuum.
Waht is your concern? Cold-welding of the rack to the pinion? Materials choice should solve that, no?
Likes LaunyO
Thanks for your answer phinds.
1) Yes it is possible. I am working on a prototype with elements from 0.1 to 6 milimeters.
2) I was afraid that some air could be blocked between the rack and the pinion.
3)I have a rod and inside it I have another one that must be able to move perpendicularly to the axis (100nm to 500nm)
The rack and pinion is mechanical and does not require air to operate.
Out-gassing from a metal component may be a problem, depending on the material and foundry process. You have not identified the materials.
You do not mention contact forces, the number of cycles, or lubrication requirement. The steel ball bearings for the rotating anode X-ray tube motors were lubricated with lead dust because it did not evaporate.
Likes LaunyO and berkeman
Thanks for your answers.
I read about out-gassing and looked at materials that can be used in UHV but my other constraint is that it must be non-magnetic. Even slightly magnetic is out of the question.
I do not fully understand what you mean. (Btw I am French, so I get by in English but it is not my native language...)
Use Google translate ...
"Vous ne mentionnez pas les forces de contact, le nombre de cycles ou les exigences de lubrification.
Les roulements à billes en acier des moteurs à tube à rayons X à anode tournante ont été lubrifiés avec de la poussière de plomb car elle ne s'est pas évaporée."
Ask specific questions. Posez des questions spécifiques.
Yeah thanks I know google translate... I still do not understand your last sentence, even translated in French.
Do any of you know with certainty a non-magnetic metal that can be use in UHV.
On some websites they say Brass or 304L Stainless steel are good and on others they say that they can be slightly magnetic...
Do NOT use stainless steel.
Use brass or bronze.
Likes LaunyO
Pure zinc from electrolytic refinery.
Zinc can be machined, or cast into a high temperature silicon rubber mold.
Likes LaunyO
How much vacuum are we talking about? 10-7 Pa? 10-9? Lower?
Likes LaunyO
Would NASA or cube-sat sites have advice on compatible non-galling, non-outgassing materials ?
Likes Tom.G
1 E-8 mbar to 1 E-7 mbar
That's not crazy high (much softer than the LHC vacuum). I'm not an expert, but see no reason 316L stainless wouldn't work.
Because 316L can be slightly magnetic.
When you machine non-magnetic stainless steel the surface and the swarf become magnetic. Then the magnetic state changes over time as the crystal structure evolves.
That's why I am not going to use stainless steel at all. I will use brass or beryllium copper.
