Radial component of del^2 in spherical coordinates?
philip041
I'm doing a question on a 3D isotropic harmonic oscillator. At one point I need to find write the radial component of del^2.
The lecturer has written 1/r^2 * d/dr * (r^2 * d/dr)
I don't understand cause it looks like he hasn't actually changed anything, r^2 over r^2 ?
In Latex, with parenthesis, the expression might be more clear:
<br /> \frac{1}{r^{2}} \frac{d}{dr} \left( r^{2} \frac{d}{dr} \right)<br />
You're taking the derivative of r^2*d/dr so the r^2 won't just cancel. Also, del^2 isn't a vector so there aren't components. I guess a more correct way would be the radial term.
Ok, I'm really confused.. why isn't the radial part of del^2 in spherical polar coords just dr^2?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
