What type of signals are needed for transmitting and receiving data from Mars?
Transmitting and receiving data from Mars requires a robust setup, including a radio antenna, transmitter, and receiver, ideally using parabolic dishes due to the vast distance. Communication with rovers often involves using orbiting satellites as relay platforms to minimize power requirements. The strength of the antennas is crucial for effective signal transmission and reception. NASA's website offers extensive technical information on related projects, particularly regarding rover communications. Understanding these components is essential for successful data transfer between Earth and Mars.
reddevil2576
I was wondering what kind of things you would need to transmit to a satellite or something on Mars and get video and whatever other signals back from there. Like transmit controls there for a rover to take and possibly to bring it back. So for the journey there and back.
A radio antenna, transmitter, and receiver. Due to the distance, the antennas should be parabolic dishes. The Mars rovers also use an orbiting satellite as a relay platform to reduce the power requirement of the landers.
How strong of one would you suggest for something like this?
You could probably find a lot of the info at NASA's website, under the pages on related projects. I'm sure the rover pages have lots of technical info, and pointers to more info.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
