When does the formula for radioactive decay become invalid?
The formula for radioactive decay, N(t)=N_0e^{-\lambda t}, remains valid as long as there is a sufficient number of atoms present for statistical averages to apply. It can be used for either one or multiple samples of radioactive material, with N_0 representing the number of atoms in the chosen sample. The decay process is based on probabilities, meaning the decay rate does not change if the sample is split. The formula's accuracy diminishes when dealing with very few atoms, as it relies on average decay rates. Ultimately, the half-life and decay laws apply broadly to any process with a large number of identical probabilities.
fluidistic
Hello,
I'd like to know when the formula N(t)=N_0e^{-\lambda t} is not valid anymore. By that I mean... since N_0 is the number of atoms at time t=0 and N(t) is the number of atoms at time "t", we see that N(t) depends of N_0. Now my question is : how do you know how many atoms should we take in count? Say we have 2 balls of plutonium, separated by 3 meters. How do you apply the formula given above? Is it still valid? Do you have to take N_0 as the number of atoms in the 2 balls, or you can apply the formula for each ball?
To be more precise, what is the minimum density of radioactive elements we can consider to have a decent approximation using the formula?
What is the "error" of the formula?
I'm sorry if this makes a lot of questions and if they're not precise enough.
It doesn't matter.
The number of decays in a period of time doesn't depend physically on the number of atoms present - it's really just another way of writing the probability of a given atom decaying within a certain time.
Obviously it breaks down when there are only a few atomspresent since it is only an average rate.
I'd generally agree with mgb's post...radioactive decay is a quantum tunneling statistical phenom so if you've got a glob of matter big enough to see likely there are enough atoms in it for statistical reasoning to apply...
I think you guys are making this harder than the original question. The answer is, you apply the equation to either or both balls of decaying material. If you apply it to both, you get the "N" vs time that is the total number in both balls. If you apply it to one ball, N is the number in that ball. The two balls don't have to know anything about each other... and ultimately, there is a probability of each individual atom decaying (thats what the lambda is in the equation)
Sorry I don't know how to write equations here, but think about this:
N = No exp(-lambda t)
so the time derivative of N (the rate of decay) is
N-dot = (-lambda)No exp(-lambda t)
then N-dot divided by N(t) (or the probability of decay) is
((-lambda)No exp(-lambda t))/(No exp(-lambda t))
=-lambda
see, the "No" drops out
Have I done that right? Does it help??
Now, can someone point me to the instructions for entering equations here?
Radioactive decay is often described in terms of the 'number of atoms present' this makes it sound like there is some hidden/quantum communication between the atoms as they decide how many are going to decay in the next second. From this explanation it's resonable to ask how you define a group of atoms - does the rate change if you split the group in two etc.
The important thing is that the half life and decay laws have nothing to do with radioactivity - they work for any process where a large number of things have the same probability of doing some event within a certain time frame.
ps. Click the 'go advanced' button in the reply - then the Sigma sign for help with latex.
I think I got it. It means that it doesn't matter if I take into consideration one ball or 2 balls, the formula would work in either cases. Nice to know.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
