Radius/Interval Convergence for Power Series
mcdowellmg
Find the radius and interval of convergence for the power series of n=0 of infinity of n^3(x-5)^n
Ratio test: http://en.wikipedia.org/wiki/Ratio_test
[(n+1)^3(x-5)^n+1 / n^3(x-5)^n]
I am lost as to how to simplify this solution to find out what the limit of n approaching infinity would be (for the radius of convergence). Since I can't find out the radius, I can't find out the interval. Any tips? I also have one other similar problem that I can't figure out for the same reason. Thanks for any help!
It's fairly simple to reduce that to
\frac{(n+1)^3}{n^3}(x- 5)= \frac{n^3+ 3n^2+ 3n+ 1}{n^3}(x- 5)= (1+ \frac{3}{n}+ \frac{3}{n^2}+ \frac{1}{n^3})(x- 5)
It should be easy to then take the limit as n goes to infinity.
Thanks! I should have noticed that one. I found the limit to be 1 and then the interval to be 5-R < x < 5+R, so 4 < x < 6.
You can extend that slightly. Notice that at x= 4, x- 5= -1 so the sum becomes
\sum \frac{(-1)^n}{n^3}
which obviously converges because it is an alternating series with absolute value going to 0.
At x= 6, x- 5= 1 so the sum becomes
\sum \frac{1}{n^3}
which is a "p-series" with p= 3 and so converges. The interval of convergence is actually
4\le x\le 6.
Thanks! I have one more problem, if you don't mind.
\sum of n=1 to infinity of \frac{(2)^{n}}{\sqrt{n}} * (x+3)^{n}
I tried to simplify it down to 1/2 by cancelling out the square roots of n and also the (-2)^{n} and (-2)^{n+1} and the (x+3)^{n} and (x+3)^{n+1} to 1 + 1 = 2. Perhaps I am going at that the wrong way?
I also thought that maybe the n=1 would make it an integral of a power series? That might be a way I should look at the problem.
For future reference, here's what your series looks like in LaTeX:
\sum_{n = 1}^{\infty}\frac{2^n~(x + 3)^n}{\sqrt{n}}
Form the ratio an+1/an and take the limit. You shouldn't be getting 1/2.
Also, why do you have (-2)n? You don't show this in what you posted.
Sorry, the latex was tricky to figure out, and in the confusion I left off the - in -2 to the nth power.
I thought it was something like that. For the LaTeX, click the summation expression in my last post to see how to do it.
This is almost exactly the same as the previous problem- where you said "I should have noticed that one"!
So
a_n= \frac{(-1)^n}{\sqrt{n}}(x+ 3)^n[/itex]<br /> then<br /> a_{n+1}= \frac{(-1)^{n+1}}{\sqrt{n+1}}(x+3)^{n+1}<br /> <br /> Since the ratio test applies to positive series, we take the absolute values so we can ignore the powers of -1. <br /> <br /> \frac{a_{n+1}}{a_n}= \frac{1}{\sqrt{n+1}}\frac{\sqrt{n}}{1}\frac{|x+ 3|^{n+1}}{|x+ 1|^n}<br /> = \sqrt{\frac{n+1}{n}}|x+3|<br /> Again, divide both numerator and denominator of the fraction by the highest power of n, here n:<br /> = \sqrt{\frac{1+ 1/n}{1}}|x+3|
