Finding the Radius of a Thomson Atom in Relation to Hydrogen Atom Radius
To find the radius of a Thomson atom in relation to the hydrogen atom radius, one must equate the charge densities of both atoms. The charge density for the hydrogen atom can be expressed in terms of its radius Rh. By setting this expression equal to that of a Thomson atom with atomic number Z, the relationship between their radii can be established. This approach allows for deriving the radius R of the Thomson atom based on the known radius of the hydrogen atom. Understanding this relationship is crucial for solving the problem effectively.
wumple
Assume that the density of positive charge in any Thomson atom is the same as for the hydrogen atom. find the radius R of a Thomson atom of atomic number Z in terms of the radius Rh of the hydrogen atom.
I don't know where to start...could someone give me a hint?
Write an expression for the charge density of a hydrogen atom (with an Rh in it). Set that equal to a similar expression for the charge density of an atom of atomic number z.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
