Radius of convergence (Power series)
ibysaiyan
Hi there,
I have just started taylor series for my course.. most seems arlgiht so far, however when it comes to validating a given series( tayor or maclaruin), I have an idea on how to find out the x value.. but I don't know what I am doing wrong.Take for example: The following function (1+x)^-1 . Expand the maclaurin series of it and give values of x for which the above series is valid:
F(x) = f(0) + f'(0)x /1! + f'' (0)x^2/ 2! + f'''(0)x^3 /3! + f^n (0)x^n/n!
Here's my working:
Let f(x) = (1+x)^-1 so f(0) = (1+0)^-1 = 1
f'(x) = -1. (1+x)^-2 f' (0) = -1 . (1)^-2
f''(x) = 2.1 (1+x)^-3 = > f''(0) = 2.1 (1)^-3
f'''(x) = -3.2.1. (1+x)^-4 => f'''(0) = -3.2.1 (1)^-4
Now initially i was puzzled on how to predict (next term or the general pattern) but I think next term will be f'4 = 4.3.2.1 (1x)^-5 so f'4 (0) = 4.3.2.1 (1)^-5
Now I know test ratio can be done to find the radius of convergence i.e for a given function say anx^n ratio would be => (an+1)x^(n+1) / anx^n...
I tried doing the same for the above series.. My general formula is : f(n) : (-1)^n . n! (1+x)^ -(n+1) ... by manipulation i got : 1.(n+1) x [ 1^-n-2] / 1^-n-1]
= > 1. (n+1) but since n => infinity , this function diverges ?
Any constructive input will be appreciated. Thanks!
Hint: think of geometric series.
I know geometric series goes like : 1+ q+ q^2 +q^3 ... and is in the form of a/1-r but how do I approach this problem ? I am confused .. can't I use ratio method to get value/s of x which converge.
Ok.. so the general form of my series is :
F^{n} = (-1)^n (n!) (1+x)^{-(n+1)}
So we can ignore (-1)^n as n -> infinity.
I am left with : (n!) (1+x)^{-(n+1)}F^{n+1} / F^{n}= (n+1!) (1+x)^{-(n+2)} / n! (1+x)^{-(n+1)}
I end up with the expression 1/ (1+x)...
EDIT: I don't mean to spam or brea any forum rules, I can find series and predict nth term.. it's only the convergence bit confusing me :(
How can you express \frac{1}{1+x} as a geometric series? If what you've given above is what you think the nth term of the series is, then it's incorrect. It looks more like f^{(n)}(x), but you can avoid calculating this by using my hint. If you're having trouble, look up geometric series in Wikipedia.
For what values of x does this series converge? I don't think you need to use the ratio test--facts about geometric series should be sufficient.
Well... a /1-r = 1/ x+1 ... I am totally lost...
hm..
hm..
If my hint isn't helping you, maybe you should go back to your original approach. Afterward I can show you the faster method I was hinting at if you're interested.
What do you get for \displaystyle \frac{f^{(n)}(0)}{n!}?
Coming back to my original approach.. Is the general form of the series wrong ? hm.. I am determined to finish ( and understand it) this problem , tonight.
Thanks for your patience with me.
EDIT: Oh i think i see where i may have gone wrong.
Previous
Shouldn't the expression (1+x)^{-(n+1)} actually be (1+x)^{-n-1} ?
The form which you have posted looks like a general form of maclaurin or taylor series hm...
EDIT: Actually i will give a little read(google) over the 'geometric approach' hm..
I think what you had for f^{(n)}(x) was right, but then you tried to do the ratio test using it. The ratio test examines \lim_{n \to \infty} \left|\frac{a_{n+1}}{a_n} \right| for a power series \sum_{n=0}^\infty a_n x^n. So, now that you have f^{(n)}(x), compute \frac{f^{(n)}(0)}{n!}, which will give you the coefficient a_n.
Previous
These are the same thing, so both are correct.
You can try looking at http://en.wikipedia.org/wiki/Geometric_series" link for geometric series. The idea is to find a way to write \frac{1}{1-x} as a geometric series, and then use this to do the same for \frac{1}{1+x}.
Did you get the answer? If you did and still want to see the shortcut using geometric series, I'll post it.
Sorry other assignments have kept me busy.. i will type down my approach in a bit.If everything fails you can post geometric method.Thanks for your concern =]
Can you show me how to get the co-efficient a_{n} ? (as above).. I am confused.. do I plug in n = 1 ?
I have used the following link as my reference... : http://www.sosmath.com/calculus/radcon/radcon02/radcon02.html
Oh do I basically find out my power series and then find out it's general form ? the maclaurin series in this case is : 4
1-x+x^2 -x^3 +x^4 -x^5
It's just as you had it above, a_n = \frac{f^{(n)}(0)}{n!}.
That looks like a good start, but you need an infinite series. What is the general pattern? You said before that f^{(n)}(x) = (-1)^n (n!) (1+x)^{-(n+1)}. So what is f^{(n)}(0)?
spamiam said:
It's just as you had it above, a_n = \frac{f^{(n)}(0)}{n!}.That looks like a good start, but you need an infinite series. What is the general pattern? You said before that f^{(n)}(x) = (-1)^n (n!) (1+x)^{-(n+1)}. So what is f^{(n)}(0)?
I believe I have finally got the solution.. it took me less than a minute to figure it out... the thing which I was over looking at was the fact that I wasn't trying to find out radius of the derivates rather than the series itself. ( As you have pointed out as well).
My series is : 1-x+x^2 -x^3 +x^4
In the general form : (-1)^n * x^n
This is An.
So the ratio which's in the form of : a_{n+1}/a{n} as n -> infinity becomes:
((-1)^n+1) *(x^n+1)/-1^n * x^n
after I manipulate them I end up with -x only... which's weird since the limit is given.. how am I suppose to plug in n -> infinity , if n's cancel... hmm
In general, the power series for a function will converge "until there is a problem". Here, the function is 1/(1+ x) which "has a problem" at x= -1. So there is no reason for the series not to converge between 0 and -1 but it obviously cannot converge to a value at x= -1.
Or, as others have pointed out, 1/(1+ x)= 1/(1- (-x)) is the sum of a goemetric series with "common ratio", r= -x. For what "r" does a geometric series converge?
This is An.
Looks good. (You can add the LaTeX markup \cdots to make it 1-x+x^2 -x^3 +x^4 - \cdots.)
That's okay. If \left| \frac{a_{n+1}}{a_n} \right| is the same thing for every n (i.e., doesn't depend on n), then taking the limit shouldn't change anything, right? For example, \lim_{n \to \infty} 2 = 2.
Read what the ratio test has to say a bit more carefully. First of all, it examines L = \lim_{n \to \infty} \left| \frac{a_{n+1}}{a_n} \right|, so don't forget the absolute values. Now, for which values of L does the series converge? For which does it diverge? And for which is the test inconclusive?
Thanks for the reply.
Would the r value be r>1 ? since if that's plugged into the equation... i get negative number. I still however am confused since typical ratio test problems have some value of x turning out to be either negative or positive value which tells of divergence,convergence of the function.
Would the x value be <1 ? since if that's plugged into the equation... i get negative number.
How do you get a negative number since you're taking the absolute value?
Like I said, read carefully what the ratio test tells you: http://en.wikipedia.org/wiki/Ratio_test
I see. So in my case L = -x, right ?
Almost, but don't forget to take the absolute value!
Ah... I see. Thank you very much for your help. I really appreciate it.
So I have another expression: ln (x+a) for which I did the above process all over again.. I end up with L = |x/a|, am I right ?
So what did you get for the radius of convergence?
I don't understand... Are you trying to find a series for f(x) = ln(x + a)?
Wouldn't that be simply L = |x| ?
f(x) = ln(x + a)
Series and the x value/s for which it's valid.
Right, and now the link from post #18 tells you for what values of L the series converges. Post what you get for the region of convergence and I'll show you the geometric series trick.
f(x) = ln(x + a)
Once again, you can either do this problem by calculating successive derivatives, or by noting a nice geometric series trick. What is the derivative of f(x) = ln(x+a) and can you see its connection with the previous problem?
Hi there, I have just had my test on this series... for which i have got 9/10 .. not bad.. for the previous question since nth term's cancel out.. and we're left with -x... for a series to be valid it must converge so I take absolute value of -x i.e |x| .. and the condition under which this series converges is when x<1.
EDIT: In case I am wrong.. I will rethink this again.. I have lecture in few minutes.
...when |x|<1! Also, remember that when L=1 the test is inconclusive, so you still have to check the endpoints, i.e. determine whether or not the series \sum_{n=0}^\infty (-1)^n x^n converges for x = \pm 1.
Okay, you've almost finished the problem, so here's the geometric series trick. We have the equality \frac{1}{1-r} = \sum_{n=0}^\infty r^n for |r|<1. You can prove this equality by noting that the series (1-r)(1 + r + r^2 + \cdots) telescopes and all terms except for the 1 cancel out. Plug in r = -x and we have
<br /> \frac{1}{1+x} = \frac{1}{1 - (-x)} = \sum_{n=0}^\infty (-x)^n = \sum_{n=0}^\infty (-1)^n x^n<br />
which is the same answer you got by computing the derivatives.
For the second problem, my hint is to calculate \frac{d}{dx} \ln(x+a) and see if you can use the first problem to get the answer.
