Rate of magnetic field change of a selnoid
The discussion centers on calculating the rate of change of the magnetic field (dB/dt) of a solenoid given an induced electric field of 45 V/m at a distance of 17 cm from its axis. Participants express confusion about how to relate the electric field measurement (V/m) to the solenoid's geometry, particularly regarding the radius and the integration process. It is clarified that the changing magnetic flux induces an electric field, which is uniform at a given radial distance from the solenoid's center. The integration of the electric field over the path will yield the circumference, which is essential for determining the magnetic flux. The conversation emphasizes the need to understand the relationship between electric fields and magnetic fields in this context.
Lance WIlliam
The induced electric field 17cm from the axis of a solenoid with a 10 cm radius is 45V/m .
Find the rate of change of the solenoid's magnetic field?
dB/dt= T/s
Faradays Law W/ the intergral due to changing position.
So \oint E*dr =-d\phi(induced current)_B_/dt
IM really not sure where to start...Advice on where to start would be VERY NICE!
Im also confused on V/m and a radii measure...not the meters but the "V".
Thankyou.
In this case the area and angle of the magnetic flux seems constant, so it should be the field that is changing. Whats happening is that the changing magnetic flux is propagating an electric field outward so that an electric field is induced across the solenoid. Since we're taking things in respect to the center axis of the solenoid, the electric field is constant throughout a circumference of equivalent radial distance. You can pull E out of the integral and integrate dr (the integration should yield the circumference).
so once the E is pulled outside the intergral I am left with "dr" to intergrate. "dr" being 45V/m? I am confused on the V/m as a measure for the radii. Why would I want the circumferance?
I guess what is comes down to is dB/dt...Is is saying Find the derivative of(magnetic flux / some measure of time)?
No, dr is increments of the path. Integrating dr gives the total length of the path, which is the circumference.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
