Calculate New RPM: Spinning Rate of 4g Bug on 12g Disk with 30cm Radius
In summary, the formula for calculating the new RPM is: New RPM = (Old RPM x Old Radius) / New Radius. To determine the spinning rate of the 4g bug on the 12g disk with a 30cm radius, you will need to plug in the values into the formula: New RPM = (Old RPM x 12g) / 4g. The 4g bug and 12g disk represent the mass of the objects involved in the spinning motion, which affects the final RPM as seen in the formula. The radius of the disk directly affects the new RPM, with a larger radius resulting in a slower spinning rate. The unit for the RPM calculation is "revolutions per minute".
joeypeter
A bug that has a mass mb = 4 g walks from the center to the edge of a disk that is freely turning at 21 rpm. The disk has a mass of md = 12 g. If the radius of the disk is R = 30 cm, what is the new rate of spinning in rpm?
Can I have some help please?
Try using conservation of anugular momentum. Also remember that moments of inertia add, so the moment of the inertia for your system is the moment of disk + moment of bug.
Sure! To calculate the new rate of spinning, we can use the conservation of angular momentum equation:
Initial angular momentum = Final angular momentum
Since the bug walks from the center to the edge of the disk, the initial angular momentum is mb x ωi x Ri, where mb is the mass of the bug, ωi is the initial angular velocity (in radians per second) and Ri is the initial distance of the bug from the center of the disk. Similarly, the final angular momentum is (mb + md) x ωf x Rf, where ωf is the final angular velocity (in radians per second) and Rf is the final distance of the bug from the center of the disk (which is equal to the radius of the disk, R).
Setting these two equal to each other, we get:
mb x ωi x Ri = (mb + md) x ωf x R
Rearranging for ωf, we get:
ωf = (mb x ωi x Ri) / ((mb + md) x R)
Plugging in the given values, we get:
ωf = (0.004 kg x (21 rpm x 2π/60 s) x 0.3 m) / ((0.004 kg + 0.012 kg) x 0.3 m)
Simplifying, we get:
ωf = 14.2 rad/s
Converting to rpm, we get:
New rate of spinning = 14.2 rad/s x (60 s/2π) = 136.4 rpm
Therefore, the new rate of spinning is 136.4 rpm.
1. What is the formula for calculating the new RPM?
The formula for calculating the new RPM is:
2. How do you determine the spinning rate of the 4g bug on the 12g disk with a 30cm radius?
To determine the spinning rate, you will need to plug in the values into the formula:
3. Can you explain the significance of the 4g bug and 12g disk in the calculation?
The 4g bug and 12g disk represent the mass of the objects involved in the spinning motion. The ratio of their masses affects the final RPM, as seen in the formula. This shows that the mass of an object can impact its spinning rate.
4. How does the radius of the disk impact the new RPM?
The radius of the disk directly affects the new RPM. As the radius increases, the new RPM decreases. This is because a larger radius means a larger distance for the bug to travel in one revolution, resulting in a slower spinning rate.
5. Is there a specific unit for the RPM calculation?
RPM stands for "revolutions per minute", which is a unit for rotational speed. This means that the calculation will result in a value with units of "revolutions per minute".
  • General Math
17K
