RC car electric start simple circuit
A communications electrician in the Navy is attempting to build a simple electric starting circuit for a Nitro Methane RC car using a 4.8v, 600mAh NiCd battery and a servo-operated micro switch. The circuit design includes branches for powering the starting motor and an ignitor, which requires careful voltage regulation. The user seeks advice on the appropriate resistor sizes needed for the ignitor, specifically questioning whether one resistor is sufficient or if a second is needed. Despite having prior electronics experience, the user has faced challenges and is looking for more detailed guidance, including circuit diagrams and measurements. The discussion emphasizes the need for community input to resolve these technical issues.
sailinghickey
I'm a communications electrician in the Navy. I went through some electronics theory about eight years ago. Now, I'm trying to build a simple circuit for an on-board electric starting system. The vehicle runs on a small Nitro Methane motor and uses a glow plug for the ignition. I'm using a rechargable 4.8v, 600mAh NiCd connected to a servo operated micro switch. From there, the circuit branches into parallell. One branch is unregulated to power the starting motor. the other branch powers the ignitor. The ignitor can only handle 1.3v.
1) What size resistor or resistors do I need to use in this system? I know one has to go before the annode of the ignitor.
2) Do I need to have a second resistor going into the cathode side as well?
Do you guys need more info or pictures? I noticed over 80 people have looked at this. Yet, no one has posted a reply. I've been trying to build the circuit through trial and error. No luck yet though.
You need to post circuits, pictures and current and voltage measurements as well as a full description of what you are trying to do.
You have some electronics experience, so you should be able to gather much of this information.
Then it would help if you could say what you have already tried.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
