Engineering RC Circuit Problem: Hi, Is Capacitor Replaced by Short Circuit?
In analyzing the RC circuit, it is noted that when t>0, the capacitor is treated as an open circuit in part b, while in part c, it is replaced by a short circuit to find the Thevenin resistance. This method involves determining the short circuit current and open circuit voltage to calculate the Thevenin resistance, which is essential for finding the time constant, RC. Alternative methods such as solving differential equations or using Laplace Transforms could yield the same results, but they may require more effort. The discussion emphasizes the importance of understanding circuit analysis techniques for accurate results. Ultimately, the Thevenin equivalent approach is highlighted as a practical solution.
sammyqw
2. Homework Equations [/B]
KCL, Node Analysis , Mesh Currents
Hi, in part b when t>0 the capacitor is replaced by an open circuit , however in part c the capacitor is replaced by a short circuit why is that?Aren't inductors the only ones replaced by short circuits?
They were looking for the resistance that the capacitor "sees" in order to determine the time constant, RC. One way to do that is to remove the capacitor and determine the Thevenin resistance as seen at those terminals. The author of the solution decided to find the Thevenin resistance by determining the short circuit current and the open circuit voltage. Divide the voltage by the current and voila, Thevenin resistance. That short circuit for the capacitor is just the application of that method.
Likes sammyqw
Is there any other way to find the same answer that you may know? Thanks for your help.
I suppose one could work out and solve a differential equation for the circuit, but that would likely be a lot of work for the same result. Or one could analyze the circuit using Laplace Transforms, again arriving at the same result after more work than necessary.
One way or another, in order to determine the time constant some work has to be done analyzing the circuit. The Thevenin equivalent is a common approach.
