What is the current in each resistor in a complex RC circuit?
kevbot010
Find the current I1 in the 1.2
resistor
at the bottom of the circuit between the two
power supplies.
Answer in units of A.
015 (part 2 of 3) 10.0 points
Determine I2.
016 (part 3 of 3) 10.0 points
Determine I3.
I=Ifinal(e^-t/RC)
V=IR
V=IR
I=V/R
I=9.5/1.2
I=7.91667A
The attachment is a picture of the circuit. I really have no idea how to solve this and could use some helpful explanation. Thanks!
Kevin
ok i understand i must use the loop rule and the junction rule.
I made it where there are two loops
Loop1:
9.5-1.2I1+2-3-5.4I2-3.1=0
Loop2:
3.1-5.4I2-8.4I3=0
I think this may be right, if it is i am still unsure of how to continue with the problem
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
