Re: Axis Transformation, time -> distance
To transform a Force vs. Time graph into a Force vs. Distance graph, the equation distance = 1/2(F/mass)*(t^2) is applicable only under the assumption of constant force. However, the relationship between distance and time is generally more complex, requiring integration of force over time. The correct approach involves using the integral of force divided by mass to account for varying forces. This complexity highlights the need for careful consideration in the transformation process. Accurate plotting depends on understanding these underlying principles.
miloko
Hi all,
I have a graph, plotted as Force vs. Time. Now, I want to plot the graph as Force vs. Distance. I'm taking distance = 1/2(F/mass)*(t^2). I think this is the right way to do it, but just need some confirmation.
Thanks,
Mike
That would work only if the force is constant. Generally, the relation between distance and time is a bit more complicated:
x-x_0 = v_0 t + \int_{0}^{t}\int_{0}^{t'}\frac {F(t'')}{m}dt'' dt'
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
