Re constant acceleration in space
The discussion centers on the misconception that a rocket cannot accelerate to speeds exceeding the exhaust velocity of its propellant. The rocket equation demonstrates that a rocket can achieve a delta-V significantly greater than its exhaust velocity, especially with a favorable mass ratio. While not all rockets are designed to exceed their exhaust velocity, it is possible for systems to be engineered to do so. The argument highlights the importance of relative motion in space, emphasizing that a rocket's speed can be measured against various reference points, not just the exhaust velocity. Ultimately, the principles of rocket propulsion allow for high-speed travel irrespective of the exhaust speed.
Filby
i was having a discussion with a friend recently and he seemed to think that you cannot accelerate to a speed which is faster than the speed of the accelerating force coming out of the back of the rocket. but i thought it was the case that u could get to very high speeds in space even if you were being propelled quite slowly and the only limiting factor was the amount of fuel u could carry.
I'm sure he's wrong but i can''t think of the killer argument so i joined this forum to see if u clever folks could sort this out for me.
i just need an example where the speed of the fuel being propelled to create acceleration is slower than the maximum speed the vehicle can reach.
thanks.
Welcome to PF!
You are correct, your friend is not. A simple model of rocket acceleration results in the rocket equation [1], which you may find useful to persuade your friend that you are correct. In particular you can show him the graph and point out that you can end up with a delta-V much larger than the exhaust velocity provided the mass ratio (final mass to initial mass) is large enough.
[1] http://en.wikipedia.org/wiki/Tsiolkovsky_rocket_equation
Filip Larsen said:
Welcome to PF!
thanks for the speedy reply . so is it true to say that nearly all, if not all, modern rockets accelerate to a speed higher than the exhaust velocity?
This is not a true statement on its own, as there are many different types of rocket systems designed for various purposes, many not including needing a high delta-V. For instance, having a high delta-V to exhaust velocity ratio for a single stage rocket is not feasible compared to other design options such a multi-staging, so you are much more likely to see a multi-stage rocket over a single stage rocket for the same delta-V budget.
What you could say, though, is that there is nothing in the principle of rocket propulsion that disallow a rocket system to be designed so that it can achieve a delta-V much higher than its exhaust velocity. For instance, the Space Shuttle has an orbital velocity of nearly 8.0 km/s (just like most other objects in low Earth orbit) whereas its engines, the Space Shuttle Main Engine (SSME), "only" has an exhaust velocity around 3.5 km/s at launch rising to around 4.4 in vacuum.
As long as the exhaust is being proelled out the back faster than the rocket is moving (in the rocket's frame of reference), then it should accelerate. Keep in mind that from a rocket's frame of reference...the rocket is moving at 0 m/s.
You can point out a simple flaw in your friend's logic to derail his argument. He says you cannot accelerate to a speed faster than the exhaust. A speed RELATIVE TO WHAT? Imagine you're in space...you might be moving at 10 km/s relative to the earth, but maybe 60 km/s relative to the sun. And probably 100s of km/s relative to the galaxy. By your friend's logic, the rocket should never move at all. Hell, it would probably move backwards.
Ask your friend relative to what, and WHY? If he says "relative to the earth", why should the rocket, in deep space, care where it "started" its journey from?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
