Reaction of strontium nitrate + copper (II) sulfate pentachloride?
  • Thread starter Thread starter sarcasma
    Copper Reaction
The discussion centers on the reaction between strontium nitrate and copper (II) sulfate pentahydrate, focusing on balancing the chemical equation and calculating the theoretical yield. The balanced equation is confirmed as Sr(NO3)2 (aq) + CuSO4·5H2O (aq) -> SrSO4 (s) + Cu(NO3)2 (aq) + 5H2O. Participants emphasize the importance of including the pentahydrate in molar mass calculations and suggest using a net ionic equation to simplify the process. The limiting reagent is identified as copper sulfate pentahydrate, leading to a theoretical yield of 1.471 g of strontium sulfate. The experimental yield of 1.41 g results in a percentage yield of 95.9%, indicating a successful experiment.
sarcasma
We are doing a lab where we react 2.00 g of strontium nitrate (dissolved in water) + 2.00 g of copper (II) sulfate pentahydrate (dissolved in water). I need to make sure that I did the balanced chemical equation right?
we eventually have to find the theoretical yield.
Sr(NO3)2 (aq) + CuSO4(aq) -> SrSO4(s) + CU(NO3)2 (aq)
I'm not sure if i put the pentahydrate (5H2O) into the equation because I'm not sure where it goes, but i think i have to because the 2.00 g of copper (II) sulfate pentahydrate is partially H20?
Seems like you are on the right track, although I am not sure if I have ever heard about copper (II) sulfate pentachloride :wink:
When calculating moles of copper sulfate you have to incorporate pentahydrate part into molar mass.
Try to write net ionic reaction, you will get rid of the copper then.
Copper is a little bit tricky here, as in the solution it is not present in the form of pentaaqua complex, but rather hexaaqua, which means that it reacts with water when dissolved. To make things more complicated copper nitrate solid will be hydrated as well, but for details you should consult some handbook. Net ionic reaction allows you to ignore all these problems.
oops i meant pentahydrate, haha sorry, i edited it. :)
will it be just ok if i use this equation, since that looks really complicated and I'm not really dealing with the other stuff, just the precipitate SrSO4
Sr(NO3)2 (aq) + CuSO4.5(H2O) (aq) -> SrSO4(s) + Cu(NO3)2 (aq) + 5(H2O)
then i would
1. find the mol for Sr(NO3)2 and CuSO4.5(H2O)-> 0.009450 mol and 0.008009 mol
2. find the limiting reagent-> CuSO4.5(H2O)
3.use ratios to find the theoretical yield for SrSO4 -> 1.471 g
4. percentage yield, i got 1.41 g in my experiment, so -> 95.9%
would this be right?
alright, thanks for the help !
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
