Reaction of strontium nitrate + copper (II) sulfate pentachloride?
  • Thread starter Thread starter sarcasma
    Copper Reaction
The discussion centers on the reaction between strontium nitrate and copper (II) sulfate pentahydrate, focusing on balancing the chemical equation and calculating the theoretical yield. The balanced equation is confirmed as Sr(NO3)2 (aq) + CuSO4·5H2O (aq) -> SrSO4 (s) + Cu(NO3)2 (aq) + 5H2O. Participants emphasize the importance of including the pentahydrate in molar mass calculations and suggest using a net ionic equation to simplify the process. The limiting reagent is identified as copper sulfate pentahydrate, leading to a theoretical yield of 1.471 g of strontium sulfate. The experimental yield of 1.41 g results in a percentage yield of 95.9%, indicating a successful experiment.
sarcasma
We are doing a lab where we react 2.00 g of strontium nitrate (dissolved in water) + 2.00 g of copper (II) sulfate pentahydrate (dissolved in water). I need to make sure that I did the balanced chemical equation right?
we eventually have to find the theoretical yield.
Sr(NO3)2 (aq) + CuSO4(aq) -> SrSO4(s) + CU(NO3)2 (aq)
I'm not sure if i put the pentahydrate (5H2O) into the equation because I'm not sure where it goes, but i think i have to because the 2.00 g of copper (II) sulfate pentahydrate is partially H20?
Seems like you are on the right track, although I am not sure if I have ever heard about copper (II) sulfate pentachloride :wink:
When calculating moles of copper sulfate you have to incorporate pentahydrate part into molar mass.
Try to write net ionic reaction, you will get rid of the copper then.
Copper is a little bit tricky here, as in the solution it is not present in the form of pentaaqua complex, but rather hexaaqua, which means that it reacts with water when dissolved. To make things more complicated copper nitrate solid will be hydrated as well, but for details you should consult some handbook. Net ionic reaction allows you to ignore all these problems.
oops i meant pentahydrate, haha sorry, i edited it. :)
will it be just ok if i use this equation, since that looks really complicated and I'm not really dealing with the other stuff, just the precipitate SrSO4
Sr(NO3)2 (aq) + CuSO4.5(H2O) (aq) -> SrSO4(s) + Cu(NO3)2 (aq) + 5(H2O)
then i would
1. find the mol for Sr(NO3)2 and CuSO4.5(H2O)-> 0.009450 mol and 0.008009 mol
2. find the limiting reagent-> CuSO4.5(H2O)
3.use ratios to find the theoretical yield for SrSO4 -> 1.471 g
4. percentage yield, i got 1.41 g in my experiment, so -> 95.9%
would this be right?
alright, thanks for the help !
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
