Reactions with crate and pulley
  • Thread starter Thread starter stinlin
    Pulley Reactions
The discussion revolves around analyzing a system involving a crate suspended by pulleys, where the center of gravity does not align with the measurements provided. Participants suggest isolating the crate to identify the forces acting on it, particularly focusing on the force in the green string. They recommend applying equilibrium equations to the system, both with and without the crate. A graphical method is also proposed, emphasizing the importance of the roller's force being perpendicular to its direction of movement. Overall, the analysis involves understanding the relationships between the forces and using vector addition for calculating reactions.
stinlin
So I had an exam yesterday and ran into a problem like this. The crate was suspended in such a way that it's CG didn't seem to line up with the given measurements. Also, the tension in the cables around the pulleys are equal (nothing is said about the tension in the blue cable). There's a pin joint at the bottom area and a roller on that incline. How would you go about analyzing this system? Mainly my question is - if you sum moments about a, what do you do about the 150 lb crate and those pulleys? Thanks!
http://img507.imageshack.us/img507/9034/lamelh0.png
^^ Image
Try looking at the crate separately. Which forces are acting on it? You should be able to find the force in the green string. Now, look at the system without the crate with the force in the green string acting on it. Write out the equations of equilibrium.
P.S. There is a neat graphical way to solve this. The force in the roller must be perpendicular to the direction of rolling. Further on, the force in the green string has a known direction, and the point of coincidence of the lines of these two forces is thereby known. Now, by drawing a line through that point and the point of the pin joint, you'll find the direction fo the force in the pin joint. Since you now have three forces, all of which directions are well known, and since you know the magnitude of one of them (the force in the green string), you can calculate your reactions graphically by simple vector addition and proper length and force scale selection.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
